d1 mule wrote:what about getting hub adaptor spacers made from 4x98 to 4x114 or whatever your wheels are, will cost you a couple hundred buckas but will be lagal and ake the car look better.
therre are guys on trade me who make spacers to any dimentions you like
Grrrrrrr! wrote:Anybody know what the legality of adding holes for a different bolt pattern on a set of alloys is? have a set of 17s that have 4x100 stud pattern and also have 4 pilot holes (~6mm) for what i assume is 4 x 114.3. However, i pick up a Lancia later this week, and its a 4x98 bolt pattern. So, can i legally get my co-worker to make me some new holes so i can throw these 17s on the Lancia, or should I just live with the standard wheels?
There is plenty of metal in the wheel, so i have no concerns about the structural integrity of the wheel, just whether the 5-0 and the insurance company are going to be a problem.
Grrrrrrr! wrote:Unfortunately its only a Thema, not an Delta HF or Integrale. Still, 2 ltrs of boosted Italian performance in something that Joe Average wouldn't look twice at could be fun.
tsoob wrote:Grrrrrrr! wrote:Anybody know what the legality of adding holes for a different bolt pattern on a set of alloys is? have a set of 17s that have 4x100 stud pattern and also have 4 pilot holes (~6mm) for what i assume is 4 x 114.3. However, i pick up a Lancia later this week, and its a 4x98 bolt pattern. So, can i legally get my co-worker to make me some new holes so i can throw these 17s on the Lancia, or should I just live with the standard wheels?
you could get those 4x100 holes slotted (you'd need to send it to me) would cost around slotted $110 +gst or slotted with inserts ($150+gst )
Quint wrote:Make a circular hole, non-circular.
h8wrxs wrote:Quint wrote:Make a circular hole, non-circular.
how is that a good option?
wikipedia wrote:The centerbore of a wheel is the size of the hole in the back of the wheel that centers it over the mounting hub of the car. Some factory wheels have a centerbore that matches exactly with the hub to reduce vibration by keeping the wheel centered. Wheels with the correct centerbore to the car they will be mounted on are known as hubcentric. Hubcentric wheels take the stress off the lug nuts, reducing the job of the lug nuts to center the wheel to the car. Wheels that are not hubcentric are known as lugcentric, as the job of centering is done by the lug nuts assuming they are properly torqued down.
