FWD Torque Steer problems
Postby Bazda » Mon May 02, 2011 3:39 pm
Truenotch wrote:
touge_ae101 wrote:oh true now that i think about it i thought about it the wrong way.... :oops:
ATAl wrote:I've heard that extra castor helps reduce torque steer
haha from my experiece more castor makes torque steer worse when i drive my car in the wet. cause i can't get wheelspin when its dry... :lol:
That could be the extra toe movement from the change in geometry due to castor adjustors?
Yes, you need to set the bump steer and change the stock rod ends to proper rob ends and move them around. sent you pm on how much you need to drop the arm using my calculations.
Postby XSVWGN » Mon May 02, 2011 8:14 pm
ok well there are all sorts of things there for me to look at. I get the car back from paint in two weeks and then its off to speedtech so i will also talk to them
My brothers work send their racecars to a Wheel alignment specialist in Wellington so i will track them down and see what can be dont too
Matt
2008 Kia rio - work car
XSVWGN
Postby Flannelman » Mon May 02, 2011 9:07 pm
Most cars I did alignments for was toe in, wheels pointing inwards. This gives stability at speed as the tyres are pushing the car together. Toe out creates a very unstable car as the tyres are trying to pull the car apart leading to very twitchy steering.
Also, FWD will never have 'bite under acceleration' as weight transfer under acceleration will be towards the rear. As this transfer happpens, the weight comes off the front wheels which may lead to the wheels going from toe in, to toe out. Being in toe out before this happens will help reduce torque steer, but be aware that the vehicle will feel different.
Flannelman
formerly known as Affroman
Postby XSVWGN » Mon May 02, 2011 9:15 pm
when boost comes on at 22psi at 355hp the car 'Bites hard right' ;)
XSVWGN
Postby Bazda » Mon May 02, 2011 9:36 pm
Gong hard right isnt really torque steer, thats another issue.
Torque steer is when it goes left to right like crazy.
Postby Mr Revhead » Mon May 02, 2011 10:07 pm
Other way around
Postby tsoob » Mon May 02, 2011 10:10 pm
need to drive it really 8)
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Bazda » Mon May 02, 2011 10:16 pm
Mr Revhead wrote:Other way around
If it pulls to 1 side only, thats the alignment of either the front or the rear being out of wack.
tsoob had this same experience and managed to find the problem being his rear suspension bushes.
Postby Mr Revhead » Mon May 02, 2011 10:17 pm
Yeah that can happen too.
But torque goes one way, not two.
Postby Bazda » Mon May 02, 2011 10:32 pm
Mr Revhead wrote:Yeah that can happen too.
Fair point.
But not in these cars :D.
Postby XSVWGN » Mon May 02, 2011 10:49 pm
It goes all over the show. Next week i will get someone to follow me and i will video things so you can all see ;)
And nick ..... i will be in Auckland in a couple of months to write a menu for a restaurant up there so we can swap cars for a bit ;)
XSVWGN
Postby 1I1 » Tue May 03, 2011 9:44 am
Might be a silly question but since getting the car back together has it had a wheel alignment at all?
TRD Clicky >>Here
1I1
Postby XSVWGN » Tue May 03, 2011 11:04 am
yea it had one recently when i had some new tyres put on :)
Matt
XSVWGN
Postby Mr Ree » Tue May 03, 2011 11:33 am
Good luck getting to the bottom of your angry Rolla Matt :)
P.S Who is painting your car? Im on the hunt for prices from people who have good reputations *wink*
wak thud gush!
Mr Ree
Postby Bazda » Tue May 03, 2011 12:00 pm
XSVWGN wrote:yea it had one recently when i had some new tyres put on :)
Matt
Bring it to me, i'll do an alignment for you to check it.
Recently Soopachargn had an alignment and they said it was all good. I checked it and they hadnt even touched the rear arms to adjust!, his car was towing out on the rear which made it twitchy.
Some times you gota wonder what these alignment shops do, guess it saves them time if its just out of spec but that will be fine.
Postby 1I1 » Tue May 03, 2011 12:15 pm
I had one place set toe in on one side in the rear and toe out on the other side :?
TRD Clicky >>Here
1I1
Postby tsoob » Tue May 03, 2011 12:43 pm
XSVWGN wrote:It goes all over the show. Next week i will get someone to follow me and i will video things so you can all see ;)
hahah you driving up?
be cool to put a face to the name tho bro if you have time..
We can have a bbq with you as the star chef :lol:
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby CelicaGT8 » Tue May 03, 2011 1:23 pm
Mine does the same thing 3sgte in Rona, hit boost and it can be a bit dodgy when your half way around a corner
CelicaGT8
Postby XSVWGN » Tue May 03, 2011 11:18 pm
haha yea nick no worries ... im sure i can make that happen. Will be driving up to give the wagon a good run in. Baz, when i come up to aucks i will get in touch and get you to look at it ..
Ree ... you have PM ;)
XSVWGN
Postby loose_unit » Fri May 06, 2011 7:54 pm
I have always run a slight toe out on my GT, there was quite a noticeable difference from having it at 0. Also run whiteline castor kit with as much postive castor as possible. Even with 230kw the torque steer was quite minimal.
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
