Re-Oiling after storing engine for a 18+ months
Postby MrOizo » Mon Jul 11, 2011 8:39 pm
What are peoples ways of re-oiling a engine after sitting around for a year or two?
Ideally pressurising a container of oil and feeding into the oil system.
Kinloud has suggested a pressure cooker fed into the oil pressure sensor would be ideal.
Fire away!
MrOizo
Toyspeed Legend
Postby strx7 » Mon Jul 11, 2011 8:49 pm
you actually dont need to do much at all, alot of late model engines we have at work can sit around for upto 5 years before being sold. pull the plugs out, full the sump with oil, crank shit out of it to get oil around the place, put the plugs back in and fire it up.
Postby MrOizo » Mon Jul 11, 2011 8:52 pm
Oh good stuff. I guess you're assuming that this is for the 2JZGTE i have - And it is.
So cranking on the starter with no plugs should see enough oil pressure?
MrOizo
Toyspeed Legend
Postby ch4ng » Mon Jul 11, 2011 9:10 pm
Yep, it should build enough oil pressure off the starter alone, should take less than 10sec on a reguarly used motor, a little longer on one thats been sitting. You may want to take the rocker cover off and give the cam lobes etc a squirt before hand as well.
Chondah Civic
2T Navara
ex:
Charade Detomaso
MX5 - Stancemobile
MX5 turbo - El Tigre
87 Alto - The Tragic 3cyl powah
AE111 BZ-G Death Race 15.09
No Limits Onsite Paint Repairs. Cut and polishing, stone chip and scratch repairs. 021-177-8539 Mention Toyspeed.
ch4ng
Postby Akane » Mon Jul 11, 2011 9:11 pm
What I did was fill it up with oil, pulled all plugs and EFI, crank 5-10sec, drained oil (that cointained water) :lol: :oops: :oops: :lol:
and refilled with fresh oil and filter, idle for a while, drain milkshake.
refilled with oil filter again, ???, skidz!
Postby tim_blair » Tue Jul 12, 2011 7:21 pm
you will wana put about a spoon full of oil into each cylinder down through the plug holes after you take them out and turn it over by hand 10 or so turns to get the cylinders and rings all oiled up then crank it over as strx7 has said
girl: can I trust you?
me: you can trust anything :D
tim_blair
Postby evil_si » Tue Jul 12, 2011 9:15 pm
You can get a pressure pre luber, forces oil thru the galleries
The last one I used was air operated, have also heard of guys using oil suction pumps and adapting to 1/8bsp and screwing into oil pressure sender port
evil_si
Postby nz_climber » Tue Jul 12, 2011 10:12 pm
I am going to just spin over my oil pump until I get some flow around the place - only works with an external oil pump though.
nz_climber
Postby rollaholic » Wed Jul 13, 2011 5:33 pm
you could put a rattle gun on the crank pulley with the plugs out if you wanted a noisy way to do it with no starter in place :lol:
