Ae86 accel cable length?
Postby stalker » Sat Jul 30, 2011 6:22 pm
Sorry if this has been answered before (hard searching with oily hands on a iph lol) but does anyone know what the length is of an ae86 acceleration cable?? How much longer is it from an ae85 cable??
AE85.6 Levin - Project car Click Here
RZ Supra formully known as EMZ RZ
stalker
Postby matt dunn » Sat Jul 30, 2011 8:43 pm
I had the same trouble when I 4AGE'd the AE85 I had.
I think from memory I used a DX corolla cable as the AE85 one is way too short.
Postby stalker » Sat Jul 30, 2011 9:39 pm
Hmmm cheers.
Yea, at a rough calc I need something that is about 19cm longer than the 85 one.
The big problem I'm going to run into will be the fact my ITB throttle linkage is mounted under the middle of the plenum so a 16v one (I'm guessing) will be too long as are 16v ones at the front of the engine? , but hoping it will only just be too long, and I can make it work if I can find out the length lol.
EDIT: 19cm not mm (sleep deprived :lol:)
stalker
Postby QikStarlie » Sat Jul 30, 2011 9:46 pm
you roughly measured 19mm?
pretty sure im using a ep82 starlet cable in my 85, cant remember how much longer it is over the ae85 one tho
QikStarlie
Postby stalker » Sat Jul 30, 2011 10:47 pm
HahhahAHHHAH, yea that could sound bad. lol.
Angled the cable as much as it would go, then got a piece of wire from the end of that to the end of the linkage, then measured the wire. Said roughly based on my blond way of measuring.
stalker
Postby AE86less » Mon Aug 01, 2011 8:44 pm
Just go to pickapart and find one a bit longer?
Shouldn't matter if it's too long as the cable works anyway..
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
