4agze idler pulley replacement - alternatives?
Postby Hachiroku » Mon Aug 01, 2011 10:13 pm
The two drive belt idler bearings on my 4agze are stuffed and I'm not keen to pay Toyota price for new ones. Has anyone here successfully adapted a pulley off something else? Does the diameter of the pulleys make any difference other than belt length i.e. can I use smaller ones?
Hachiroku
Postby evil_si » Mon Aug 01, 2011 10:37 pm
with the pulley kits I do I normally use a 4age cam belt tensioner with a 3mm spacer behind it
i remove the spring tensioner bracket to tidy them up.
they are a smaller diameter so a shorter belt would be required
evil_si
Re: 4agze idler pulley replacement - alternatives?
Postby LEAKER » Mon Aug 01, 2011 10:49 pm
Hachiroku wrote:The two drive belt idler bearings on my 4agze are stuffed and I'm not keen to pay Toyota price for new ones. Has anyone here successfully adapted a pulley off something else? Does the diameter of the pulleys make any difference other than belt length i.e. can I use smaller ones?
Repco have a catalogue with new idlers in them. Quite a few different ones. Thy're around 80 - 90 bucks each i think. Not too bad. Or try fensport uk. They do a great range for the gt4s and im sure for other cars as well.
The GT4 is to Celicas what the GTR is to skylines.
LEAKER
Postby Rick » Mon Aug 01, 2011 11:50 pm
Why don't you replace the bearing in the idler? of course it has to be the type that you can replace bearing.
Postby Hachiroku » Tue Aug 02, 2011 8:51 am
No, bearing isn't replaceable unfortunately and can't find anything in Gates catalog to match. evil_si - is that the standard 16v tensioner with the slotted hole?
Hachiroku
Postby rollaholic » Tue Aug 02, 2011 1:48 pm
what are the toyota prices, out of interest?
Postby evil_si » Tue Aug 02, 2011 5:07 pm
Yup the one with the slotted hole
evil_si
Postby LEAKER » Tue Aug 02, 2011 6:12 pm
Hachiroku wrote:No, bearing isn't replaceable unfortunately and can't find anything in Gates catalog to match. evil_si - is that the standard 16v tensioner with the slotted hole?
not a gates catalogue. They have a repco brand book.
LEAKER
