E85, anyone using it?
Postby Flannelman » Sat Oct 29, 2011 1:05 pm
Anyone using E85? Where is your supply from and cost per litre?
Flannelman
formerly known as Affroman
Postby RedMist » Sat Oct 29, 2011 6:10 pm
I'm running, and am very pleased with E30. I would be running E85 but I currently burn 113 liters (out of 120) in a 250km enduro. E85 would mean either a larger tank (which isn't possible) or a refuel (and I'd loose).
The offroader runs cooler on E30 (than av gas) and produces almost identical power at the same boost levels. Turbos are spooling slightly later (250RPM) however this may just be a function of tuning, as I clipped Walter (NZEFI) while he was playing and surging the turbo's. I'll never use 2500RPM in a sequential box with 118kph first gear.
On the emotive side. The car just sounds "happier". It doesn't sound like it's a bunch of metalic parts trying to rip each other to pieces and as such I'm using more RPM. It's hard to quantify, but the additional fuel may be giving it a wetter sound, which doesn't have that high pitch metalic bark that lean burn gives.
I'm running alcothane . Prices on the alcothane.co.nz website.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby matt dunn » Sat Oct 29, 2011 7:59 pm
Do you get that direct or through NZEFI.
I have also run E30 from in my car, on the dyno and at the drags.
Does run much better and makes more power but again the fuel consumption and the size of the fuel tank factor in as well as the price.
With E85 I doubt my tank would be enough for the 8 Lap race.
