Need Ideas for something to put my vvti 1jz into (gx71?)
Postby Brawler » Sun Oct 30, 2011 4:35 pm
HI!
So Plan was to put the 1jz and W55 set up into a Celica XX. Have a factory F series lsd for it too, but my diff subframe is a bit worse for wear, So I have decided I don't want to do the swap into the celica.
I can easily get a GX71 shell and go down that road, Im just wondering what it would be like as a street car, are they a very good platform to go on?
What shell would you recommend for my 1jzgte?
zing! Sig got nuked. Sorry bout that.
Brawler
Postby Lloyd » Sun Oct 30, 2011 6:32 pm
Gokart, and build a mini JZA70 shell around it
Postby Stott69 » Sun Oct 30, 2011 8:33 pm
Get a Frasier 7 kit! and turbo it!
Stott69
Postby nz_climber » Sun Oct 30, 2011 10:38 pm
Don't think you would have much luck shoe horning a 6 cylinder engine into a fraser, engine bay is just not long enough with the inboard shocks.
for reference here is a beams 3sge shoe horned in one.
Other 7 replicas you might get lucky and fit it in.. (my Mcgregor has a bit of room in the front as shown below) but gets taken up quickly with remote oil filter, airbox, steering rack and other random bits
nz_climber
Postby Lloyd » Mon Oct 31, 2011 7:37 am
Plenty of room in other 7s, have seen RBs and all sorts of things put in them
Postby rollaholic » Mon Oct 31, 2011 5:50 pm
GX71 is a pretty typical 80s japanese sedan. in other words, a bit shit. perfectly fine for thirsty daily driver / skid hack, it all depends what ya want out of it i guess.
Postby cogent » Mon Oct 31, 2011 5:54 pm
E30 or E36 BMW 3 Series
190e
R32 Skyline
cogent
Postby d1 mule » Mon Oct 31, 2011 6:33 pm
cross breeding engines makes me :cry:
d1 mule
Postby sergei » Mon Oct 31, 2011 6:33 pm
Altezza
Postby 1I1 » Mon Oct 31, 2011 6:44 pm
sergei wrote:Altezza
+1
TRD Clicky >>Here
1I1
Postby phoenix » Mon Oct 31, 2011 7:01 pm
E Type Jag.
phoenix
Postby Alex B » Mon Oct 31, 2011 7:07 pm
phoenix wrote:E Type Jag.
*face stab*
Well ok, long as its a series 3.
Postby tiny2009 » Mon Oct 31, 2011 7:17 pm
tiny2009
Postby ryanfels » Tue Nov 01, 2011 7:33 am
rollaholic wrote:GX71 is a pretty typical 80s japanese sedan. in other words, a bit shit. perfectly fine for thirsty daily driver / skid hack, it all depends what ya want out of it i guess.
My 2jzgte is just as thirsty as the orginal 1geu (unless your pushing it of course).
the VVTI JZs are a bit tricky to make work in non-ABS cars if your keeping the factory ECU. They like to get signals from the dash and ABS but there are ways around it.
thegreatestben wrote:It's lucky you arent a douchebag other wise I wouldn't help you :wink: :wink:
mark 2 gx61 2jzgte powered - viewtopic.php?t=72619&start=0
Discussion - viewtopic.php?t=72620
ryanfels
