1997 corolla 5 stud conversion
Postby Bazda » Mon Nov 07, 2011 9:50 pm
strx7 wrote:there is a pretty good chance the entire front hub will bolt straight on. i know st170 corona 5x100's do.
It prob will, but you will need to check the ackerman angle on the steering arm, the angle and height off the lower ball joint etc.
I tried getting a hub with the reverse steering arm but the ackerman was totally out which would make steering the car very interesting!
Postby strx7 » Mon Nov 07, 2011 10:13 pm
ST170 front hub carriers look like they possibly the same casting as AE90/ae100. ST190's appear to be pretty damn close too. St190 and ae100 share the same bottom arms
Postby Bazda » Mon Nov 07, 2011 10:25 pm
strx7 wrote:ST170 front hub carriers look like they possibly the same casting as AE90/ae100. ST190's appear to be pretty damn close too. St190 and ae100 share the same bottom arms
Have a hub with you? if I could find one thats what your talking about id def change mine :D
Postby Anth_555 » Tue Nov 08, 2011 6:54 am
you cant realy redrill becose ther tomany other holes in the way . 5x100 hubs have bigger bearings so i dont think youll find new flanges to go in.
i know rav4 hubs got strgiht on to st185. if you can get st190 stuff on ull be able to put rav4 stuff on. as for breaks use the rav breaks last ones i looked at looked rather big
-1984 Trueno AE85
-1993 Surf LN130
Anth_555
Postby Bazda » Tue Nov 08, 2011 7:32 am
Nothing to do with too many other holes in the way Antz.
The actual flange is too small in diameter to even put a PCD of 4x114.4.
Postby strx7 » Tue Nov 08, 2011 10:13 am
yeah the ravs i have looked at have had 305mm or there abouts discs on the front but they are only 18mm or similar wide.
Postby Anth_555 » Tue Nov 08, 2011 6:02 pm
i was meaning re drilling to 5x100 on the back you have extra holes for getting at the hand break theres no room to put new holes[/quote]
-1984 Trueno AE85
-1993 Surf LN130
Anth_555
