Pivot Voltage Stabilizer
Postby hare » Sun Jan 08, 2012 1:30 am
taken it off before sold the car today,once it's off,the car idle a bit rough(it getting a bit better after a run) and the engine shake a bit when the air-con fan kick in,seen it's not enough earthing...etc? should I took off the ECU fuse to reset the ECU?thanks for reading.
hare
Postby Adoom » Sun Jan 08, 2012 9:52 am
Huh!? :?
WTF did I just read??
Your explaining skills need more work.
You have one of those "magic" voltage stabiliser things that is supposed make your car run "better"??
You took it off, now your engine shudders when the AC comes on???
Adoom
Postby iOnic » Sun Jan 08, 2012 10:26 am
Sounds like it hasn't got enough earths Alfred. Add a few more from the battery negative terminal to the engine block and that should sort it. Otherwise there's something wrong with the idle controller that's stopping it from raising the idle for aircon. Does it try to stall when you steer from lock to lock at idle (assuming it has power steering). Resetting the ECU *could* help.
Postby allencr » Sun Jan 08, 2012 12:36 pm
SPAM
allencr
Postby Mr Ree » Mon Jan 09, 2012 1:51 pm
Sounds like a loose earth at one of the points, either on the chassis or block.
Or the battery terminal itself?
wak thud gush!
Mr Ree
