Radiator filter
Postby saft » Fri Feb 10, 2012 4:59 pm
i just got a filter sock from the local radiator place.
undo top hose, slip over radiator end, push the tail into the radiator, put hose back on.
looks a bit like a finger off a cotton glove, caught a lot of crap in my cooling system.
027 516 0556
I f**king love cheeseburgers.
saft
Postby 1I1 » Fri Feb 10, 2012 5:09 pm
Is it something that you only leave on for a short time?
Otherwise it could stop the flow of water/break due to all the crap collecting in it?
TRD Clicky >>Here
1I1
Postby Mr Revhead » Fri Feb 10, 2012 6:44 pm
Quint wrote:pressure is force over area :/
You know what I mean.
Trying to force too much water through it could damage things.
Then again if you are in an area with low water pressure maybe all you will do it blow back though your pipes :lol:
Postby saft » Fri Feb 10, 2012 6:53 pm
1I1 wrote:Is it something that you only leave on for a short time?
I ran mine for about a week and cleaned it, left it in for another month and it caught bugger all
027 516 0556
saft
Postby CelicaGT8 » Fri Feb 10, 2012 9:14 pm
Condoms are safer
CelicaGT8
Postby Mr Ree » Sat Feb 11, 2012 10:15 am
Intersting info there, Saft.
How much did they charge you for the cock sock?
Might look into running one for a while just incase I have any crust left in my CS.
wak thud gush!
Mr Ree
Postby gt4dude » Mon Feb 13, 2012 12:27 am
Mr Revhead wrote:I can sell you a proper coolant filter if you want.
But if I were you I'd be looking to overhaul the system properly
Is it like the one in limbo's post?
saft wrote:i just got a filter sock from the local radiator place.
Thanks saft
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby gt4dude » Mon Feb 13, 2012 12:35 am
I'm gonna tip the radiator upside down and hang it up, block off the hot port and jam the garden hose in the cold port and the radiator cap should help pressure remove the crap in there, then that filter should keep it good from then on...
200AWKW / 370NM
gt4dude
Postby Mr Revhead » Mon Feb 13, 2012 8:15 am
The filter I was talking about is for trucks etc. Its actually not a filter as such. But contains pellets that dissolve prolonging coolant life.
I really do think a filter is a bad idea. It will concentrate all gunk and potentially block it up.
Postby gt4dude » Mon Feb 13, 2012 12:28 pm
I'm very used to reading the temperature gauge and pulling over when it creeps, etc. After every drive I check my coolant, I'm very used to having a blocked radiator, I'd rather have a little mesh filter to clear out every time rather than go through radiator after radiator...
200AWKW / 370NM
gt4dude
Postby sergei » Mon Feb 13, 2012 12:39 pm
The thing is that the coolant should not have any particles in it.
If it has there is something wrong.
So if you eliminate what is causing particles (bad coolant) and clean the system thoroughly, you should not need any filters.
Of course if it has been under kiwi maintenance for a few years, then the block is rusted to bits and you will have no end of rust flakes collecting on the bottom of the radiator, but putting a filter is not going to help that (it will block pretty fast).
you will need to chemically clean the cooling system to get rid of flakes, but that is dangerous because it can remove excess and cause leaking head gasket.
Without chemical cleaning it will take years for it to normalize, meanwhile once a few month you can drain and clean radiator....
Kiwis need to attach a zinc brick inside of the block the way they service their cars....
Postby limbo » Mon Feb 13, 2012 1:52 pm
I have used the sock type as well on my AE85, they work well caught heaps of rusted 3A block. So much that it did block up completely after the first 30min, but then less after that, and after about 3 socks worth it was pretty clear so I could put on a new radiator without fear of blocking that up.
Worst bit was when the sock ended up inside the radiator top cap and so full of rust i couldn't pull it back out again. had to use a tiny spoon to empty the sock enough.
The point to the fancy aluminium one that I posted about is that it is easy to check and easy to clean. If it slowly starts to block your temp will slowly rise and when you see that you can clean it in 2min after its all cooled down then happy days.
limbo
Postby allencr » Mon Feb 13, 2012 6:33 pm
gt4dude wrote:I'm gonna tip the radiator upside down and hang it up, block off the hot port and jam the garden hose in the cold port and the radiator cap should help pressure remove the crap in there, then...
Got good water pressure & 19mm garden hose & only very loose stuff clogging it? If not, it'll stay put. Any radiator with 1/2 its tubes clogged will still be able to easily handle any garden hose, hence the 'air' helper.
allencr
