ch4ng wrote:Yep VHT exhaust paint is great, you can also get it from BNT (wheel paint was $6.5 a can so the exhaust paint won't be too much more)
Heylin wrote:+1 on VHT, currently using on my Subtech downpipe, and my old MR2 had it on its turbo exhaust housing and screamer pipes (= very hot) still looked good after a year of running.
Its all in the prep work and correct curing process.
XSVWGN wrote:I purchased the VHT 1300-2000 degree farenhite paint. True-no-turbo is sand blasting my manifold and then heating it up with a gas torch then applyng the paint as thats the best way apparently
Matt
Mr Ree wrote:I had my turbine housing, exhaust manifold, down pipe and dump pipe coated at procoat and have to say I wasnt very happy with the job.
Upon removing it from the box, the coating was noticeably inconsistent, some areas had less than half the amount that other areas had, and it was nowhere near as durable as I would have expected given the cost. Even the slightest of knocks or bumps removed the coating and it didnt take many heat cycles for it to thin even more in places.
At a guess, whatever their process is, I presume that part of the prep stage was omitted, or done a bit too casually, as I have seen their work on cars in magazines and the difference is night and day.
Mr Ree wrote:Yeah I imagine thats all it was too, and to be honest, thats whats most annoying about it. Knowing it could have been done properly but wasnt due to being a friday arvo, or monday morning etc.
It was the high temp black satin coating and it cost about $500 if my memory serves me correctly.
Users browsing this forum: No registered users and 39 guests
