Translate for me please/ help diagnose uzs141 fault
Postby thegreatestben » Mon May 14, 2012 11:01 pm
Can any one read what this says in Japanese?
I believe it is to do with the trc system as that light illuminates also. Fault only appears when I'm off the throttle. Goes away when driving at any speed. As long as my foot is on the the throttle it stays off. As soon as I lift my foot off the waning comes up along with a bing.
Thought it was brakes at first but they don't seem to vary the warning in any way.
Cheers in advance.
thegreatestben
Postby thegreatestben » Tue May 15, 2012 12:07 am
Apparently it says "do a burnout" because that fixed the problem seemingly. Suspect a lack of use caused it to bring up the fault. Giving it something to do has solved it for now.
thegreatestben
Postby rollaholic » Tue May 15, 2012 8:49 am
gotta love the japanese.
Postby Bling » Tue May 15, 2012 9:33 am
Sweet digi dash 8)
Postby Jdawg » Tue May 15, 2012 9:41 am
"VTEC is currently unavailable"
Jdawg
Postby Mr.Phreak » Tue May 15, 2012 9:53 am
It's an Engine Electrical System fault, you won't know more til you run diagnostics
Mr.Phreak
Postby thegreatestben » Tue May 15, 2012 1:41 pm
Couldn't find the standard diagnostic terminal in engine bay. There's a lot in there though and it was only a brief look. Post burn out results are good, didn't do it last. Night or this morning on the way to work. Now to fix the intermittent display of said digi dash/HUD
thegreatestben
Users browsing this forum: Google [Bot] and 49 guests
