Brake pad and rotor wear in race car - thoughts?
Postby TWSTD » Sat Jul 14, 2012 10:32 pm
Hi peoples.
Im somewhat stumped as to why we are wearing pads so quickly in our race car (evo powered 4wd charade). Current brake setup is EVO 3 front calipers and znoelli S12 heat treated motorsport rotors with PMU racing 999 pads. We have chewed through a set of pads in 2 outings! I know they are getting very hot and all i can summise is that although the heat is not sufficient to fade them (ie over 850-900 degrees C) it is hot enough to cause a substantially accellerated rate of wear. Incindentally i had Pagid RS4-2 (blues) in the prior and they went down in a similar time but also suffered some fading issues. We since had some ducting made from the front bumper to the centre of the rotors.
Surely its not normal to get only about 180 race kms (about 70 laps of hampton downs) out of a set of pads? I know this charade is somewhat faster than my old race car but we used to get a whole season from a set of front pads in that!
Also note the uneven wear on either side of the rotor in the photos below. Is that just due to it being a basic twin pot caliper?
Images:
http://www.drivenperformance.co.nz/imag ... 99sml1.jpg
http://www.drivenperformance.co.nz/imag ... 99sml3.jpg
http://www.drivenperformance.co.nz/imag ... 99sml2.jpg
http://www.drivenperformance.co.nz/imag ... rs1sml.jpg
@@@ Online store NOW OPEN! @@@
Click here!
DPR | HTS | SARD | WALBRO | GARRETT | SPEC | EXEDY | MINTEX | HKS | APEXi | MAPECU | SIMOTA + more!
TWSTD
Postby strx7 » Sat Jul 14, 2012 11:17 pm
IMHO non slotted discs would make them last longer. the 310mm discs i had on the front of the ae104 were slotted and ate through pads at that rate if not quicker.
Postby pc » Mon Jul 16, 2012 12:33 am
Get something with at least a piston on each side, that will create more even wear left to right.
PMU site doesn't have a 999 compound, what are the specs of that? Bigger rotors with bigger pads should mean the brakes wont get as hot, but first thing is to make sure the pad compound is a good one.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby TWSTD » Mon Jul 16, 2012 7:08 am
Click here!
TWSTD
Postby pc » Mon Jul 16, 2012 10:17 pm
oh, I looked here http://www.pmuracing.com/?page_id=2
It looks like a good compound, maybe the pads/rotors just need to be bigger.
red car
Manfield - 1:24s
pc
Postby CAMB01 » Mon Jul 16, 2012 10:22 pm
Those pictures look pretty much like my race brakes do now after about 28 laps at manfeild.
Although my car is heavier im still running the same calipers with Ferodo DS3000 pads. I get pad fade after 3 laps.
Id be upgrading to piston either side and larger discs.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby cat007 » Tue Jul 17, 2012 10:31 am
What's up with the rotor being all crazy cracked? Is that a heat thing or?
Postby TWSTD » Tue Jul 17, 2012 10:42 am
Yes.
Click here!
TWSTD
Postby cat007 » Tue Jul 17, 2012 12:05 pm
And it's bad?
Postby Dunny » Tue Jul 17, 2012 10:20 pm
They have seen some serious heat alright, that would be the 1st thing I'd be getting sorted out, have you run some temp paint or the likes to see actual temps?
You need to get temps down to get a suitable pad working correctly, how much brake bias to the front have you got...are your rears doing anything?
Extreme heat will kill most pads in no time at all, especially once they get some wear. Looks like you are well under braked or have lack of air for cooling for the speeds
'81 KP61 uprighted 4k racecar (built by Rush Automotive)
'72 KP30 2 door
Dunny
Postby matt dunn » Tue Jul 17, 2012 10:38 pm
The vanes in the rotors, are they curved or striaght?
Postby Bazda » Wed Jul 18, 2012 2:40 pm
Brakes are too small IMO.
Also need 4 piston calipers that will create more even wear.
Either upgrade to later model evo brembos or custom fit something else.
Postby cat007 » Wed Jul 18, 2012 2:42 pm
Bazda wrote:Brakes are too small IMO.
Yeah - get a BBUP - Barry's Brake Upgrade Package :P
