Hey all, i grabbed a couple turbos for next to nothing to get rebuilt and highflowed, i was told they came off a 2jz which looking at the bolt ups for manifold seems correct.
Problem is there isnt any markings on the turbos to confirm or deny they are CT20's, so i took off the turbine and compressor housing to measure the wheels:-
Compressor inlet:
Compressor outlet:
Turbine inlet:
Turbine outlet:
I found this link, seems to confirm but would like some input from you knowledgeable fellas!!
http://www.turbosupras.com/pages/en/pages/technical/CT20%20turbochargers.htm
