Lexus V8 Questions?
Lexus V8 Questions?
Postby matt dunn » Sat Nov 03, 2012 10:47 pm
Anyone here had much to do with the Lexus V8 conversions?
Helping with a project fitting one to a race car and has a thingee on the front which we are unsure about?
Supposedly the engine is from a Celsior,
and I suspect it may be to do with hydraulic drive fans?? if thy had that.
Here is a picture of the engine,
The thingee is question is in blue in the middle. Looks like a water pump but apparantly it is not.
There is a electric solenoid in the green in the picture which I presume is part of it as it is a non-VVT engine,
and there are three outlets/pipes yellow green and Blue?
What do we do with these? can you just block them off, or loop them? Or other?
Postby evil_si » Sun Nov 04, 2012 8:15 am
Hydraulic fan drive,
Best way is to unbolt it completely, it leaves a big hole in the front covers, there have been a few guys that sell cover plates for when its removed.
Yes all the circled bits are part of it,
evil_si
Postby Zestripper » Sun Nov 04, 2012 9:08 am
You can also put one of these in its place: http://www.trademe.co.nz/motors/car-par ... 479166.htm But seeing as it's a race car I assume you wont be using all the standard accessories and standard sepentine belt so as Si says just remove it and blank it off.
Zestripper
