Grrrrrrr! wrote:sergei wrote:
3) Brand new ST205 pump is a tad over $100, and flows well enough to satisfy your needs (or any other needs).
So what flow rate exactly does a st205 pump provide at 5psi,8psi and 10psi, i'd love to know, because so far i haven't been able to find any actual data on what that pump flows. Then if you could just tell me exactly what my needs are it'll save me a bit of time and a bunch of heat transfer calcs.. kthxbye.
Grrrrrrr! wrote:On a hot day, there is roughly 30kW of heat to lose to get intake temps to where i want them (about 30* above ambient) judging from ballpark figures I punched into the borg warner turbo selector website.
Piping may have to get larger to keep the restriction down to 5psi max, but high flow is the only option to keep the size of the intercooler core and heat exchanger reasonable.
Grrrrrrr! wrote:turbo outlet temp 325F = 162*C (from matchbot)
Mass flow = 0.302kg/s (from matchbot)
desired throttle body temp 60*C
DeltaT = 102*C
specific heat capacity of air ~1 kJ/K.kg
0.302 * 102 * 1 = 30.8kW.
and thats only at 400 hp power levels.
nz_climber wrote:Faster water flow through the radiator core will not always be better, there needs to be time for the heat transfer to occur.
Maybe something to consider.. (not sure on the exact figures so happy to be proven wrong)
Grrrrrrr! wrote:nz_climber wrote:Faster water flow through the radiator core will not always be better, there needs to be time for the heat transfer to occur.
Thats just another internet myth.
Grrrrrrr! wrote:Correct, the rate of heat tranfers is dictated by the temperature difference which is why more mass flow wins every time. More mass flow means you are pushing the water that has already cooled away from the face of the heat exchanger and replacing it with warmer water, therefore it is more efficient.
That graph is irrelevant, thats for heat transfer between two masses in a closed system. Not relevant to an open system with net energy changes.
Go to this website and play with the calculator. Setup some numbers, then double one of the flow rates... result is more heat transfer, everytime.
matt dunn wrote:
http://i277.photobucket.com/albums/kk58 ... pic860.jpg
shows the pump for the radiator, as the engine had no water pump itself anymore.
