AE86 radiator into AA60?
Postby Hachiroku » Thu Jan 31, 2013 11:57 am
Looking at a new radiator for an AA60 but not much available aftermarket in NZ. The AE86 ones look to be a pretty similar design - any idea if they are compatible? Would be a cheaper and easier option than trying to make something else fit or sourcing a Carina one.
Hachiroku
Postby KinLoud » Thu Jan 31, 2013 1:54 pm
From distant memory....
Isn't there a plastic plate blanking off part of the hole where the radiator fits in the AA60?
Pretty sure it uses a radiator similar in size to the AE86 for the A series engines
Postby Hachiroku » Thu Jan 31, 2013 2:37 pm
Yeah there is. Just wasn't sure about the spacing of the top mounts or bottom lugs. Would make life nice and easy if its a straight bolt in.
Hachiroku
Postby crispy'86 » Thu Jan 31, 2013 10:06 pm
I've got an ae85 radiator which prob isn't really suitable but if it's a cheaper option for you it's here. Will need to be recored as it's a bit worse for wear
crispy'86
Users browsing this forum: Google [Bot] and 28 guests
