4k to 4age
4k to 4age
Postby h8wrxs » Wed Feb 06, 2013 11:08 pm
i cant be arsed researching this myself as its not my project but a friend asked me for info
he has a dx corolla wagon with a 4k engine and 4spd gearbox (cant remember year)
will a 4age with t50 gearbox bolt straight into it? or do you need different crossmembers etc, does the gearbox fit in the tunnel etc etc
i dont like dx's hence i cant be bothered researching it :D :D :D
any help would be appreciated
The four seasons in Australia consist of "$&#$% it's hot", "Can you believe how $&#$% hot it is?", "I won't be in today because it is too $&#$% hot" and "Yes, the dinner plate size spiders come inside to escape from the heat."
h8wrxs
Location: travelling to candy mountain with my magical leoplurodon
Postby d1 mule » Thu Feb 07, 2013 12:42 am
wont "bolt in" can buy mounts on TM for a couple hundy.
T50 will fit in the tunnel, i think the t50 x member will work with a bit of hole slotting
Will need a suitable driveshaft
Will need to get a TE71 Hydraulic clutch pedal box / modify the cable pedal box.
obviously wiring
fuel pump + a new fuel line from the pump to the rail, can use the factory feed as the return.
those are the main bits from memory, If he can track down a AE70 Xmember the engine will bolt in.
d1 mule
Postby Lurkin » Thu Feb 07, 2013 9:31 pm
Surely AE71 mounts would also fit? Im assuming its a ke70 wagon?
Past casualties
1986 4age liftback (sold)
1985 4age aw11 (well crunched)
1993 ae101 gt apex levin (sold)
Lurkin
Postby wde_bdy » Thu Feb 07, 2013 9:41 pm
Lurkin wrote:Surely AE71 mounts would also fit? Im assuming its a ke70 wagon?
No, crossmember is different between K/T/A/C versions of the 70 chassis. As it is a wagon then check if it has rack and pinion, can't use an A series crossmember without mods to the steering column mounting point on the firewall if it has a steering box.
Callum
wde_bdy
Postby matt dunn » Thu Feb 07, 2013 9:43 pm
No because an AE70 has a cross member with mount to suit an A series engine,
and a KE70 has a different cross member with K series mounts.
If you fit an Ae70 cross member they will bolt in,
But A series cross member + A series engines mounts
will be at leatst 2x the price of the K to A mounts off trademe.
Postby d1 mule » Fri Feb 08, 2013 1:02 am
To Quote myself
d1 mule wrote: If he can track down a AE70 Xmember the engine will bolt in.
d1 mule
Users browsing this forum: No registered users and 34 guests
