celica gt4 hubs on ae101 corolla 5 stud conversion
Postby mega4a » Sat Feb 09, 2013 11:41 am
does anyone know if celica 5 stud gt4 hubs bolt up to corolla?
was looking at pick a part and they look very similar the celica was a non turbo but was still the gt4 shape. anyone done a 5 stud conversion b4?
mega4a
Re: celica gt4 hubs on ae101 corolla 5 stud conversion
Postby sergei » Sat Feb 09, 2013 11:45 am
mega4a wrote:does anyone know if celica 5 stud gt4 hubs bolt up to corolla?
Depends which celica. Yes they will bolt on providing it is McPherson to McPherson. You will have issues with positive camber, about 3-4cm ride height increase and too much Ackerman if you use ST20X hubs on AE101.
ST18X hubs will have fatter bolts, ST16X hubs will be bolt on. There could be issues with balljoints (too short, too small etc.)...
Although some one will have to correct me if I am wrong (as I could be wrong there).
Postby XSVWGN » Sat Feb 09, 2013 12:09 pm
Ask shrike as he has celiac hubs etc in his ae111 levin
2008 Kia rio - work car
XSVWGN
Postby ap7 » Mon Feb 18, 2013 1:16 pm
SV21 Camry front hub stubs fits Levin's/Trueno's.
See this link as well:
http://www.toymods.org.au/forums/tech-c ... 114-2.html
ap7
Postby ap7 » Mon Feb 18, 2013 1:29 pm
The front bearing kit that fits into the Levin/Trueno hub is IBS 1163.
The rear bearings are Celica ones and the rear stubs need to be machined down alittle.
ap7
Postby Shrike » Mon Feb 18, 2013 2:19 pm
XSVWGN wrote:Ask shrike as he has celiac hubs etc in his ae111 levin
front ones are minor difference and ill be going for a lca kit from barry in the future to sort out geomentarty etc but if you use the s/s tie rod ends its pretty close from memory steering wise
why do you want to go to 5*100 anyway?
Shrike
Postby mega4a » Tue Feb 19, 2013 10:25 am
idk why not bigger brakes for cheap if i can get a pick a part set.
and 5 stud has some pretty cool but cheap wheels out there.
mega4a
Postby Shrike » Tue Feb 19, 2013 11:08 am
5X100 is a prick to get wheels for and the right offset hence why ill be converting to 5x114.3
you can use the gt4 front 2 pot calipers with the factory machpherson ae101 disks
Shrike
