Noisy gearbox/drive line
Postby cat007 » Mon May 06, 2013 11:12 am
Hey all
Last week I jacked all 4 corners of my car up to replace my rear gearbox seal.
While it was up I ran the car in gear, through all gears, to get the oil moving around in the gearbox and see if the new seal was doing it's job.
I noticed what appeared to be an alarming amount of drivetrain/gearbox noise in all gears.
The gearbox is a W55 with unknown km's. It changes pretty nice - and there doesn't appear to be a large amount of noise from it when you're driving - although I'm sure my exhaust is drowning some of it out.
The noise I heard wasn't grinding or whining or anything bad - just sounded like loud drive train noise. Perhaps it's perfectly normal - who knows. Maybe I should jack her up again tonight and record it (my car, not the misses).
Anyway - perhaps there's someone on here who can recommend an additive to shut a W55 up a little bit?
Hunt
Postby Mr Ree » Mon May 06, 2013 12:19 pm
What oil is in it? MT90?
wak thud gush!
Mr Ree
Postby cat007 » Mon May 06, 2013 12:36 pm
Mr Ree wrote:What oil is in it? MT90?
This:
http://www.gulfwestern.com.au/Gear_Lube_Low%20Vis.html
Low Vis Gear Lube 75W-90 - GL-5
Postby Mr Ree » Mon May 06, 2013 12:45 pm
Im pretty certain the w55 takes a GL4 oil, not that Im saying that will be what is making the box noisy, but still, best to run the proper oil anyway.
wak thud gush!
Mr Ree
Postby cat007 » Mon May 06, 2013 3:25 pm
Mr Ree wrote:Im pretty certain the w55 takes a GL4 oil, not that Im saying that will be what is making the box noisy, but still, best to run the proper oil anyway.
Yeah - here's a good article:
http://www.widman.biz/uploads/Transaxle_oil.pdf
BNT want $44 per quart for MT90 - OUCH.
Any MT90 hookups on here?
Postby Mr Ree » Mon May 06, 2013 4:10 pm
Yeah, its not cheap by any means, but well worth the investment I think.
TM vendors sell it slightly cheaper sometimes, but then freight puts it up to the same price unless you buy in bulk.
wak thud gush!
Mr Ree
Postby Lloyd » Mon May 06, 2013 7:03 pm
A lot of cars will make a hell of a noise with no load on the drivetrain. If it doesn't do it on the road then don't worry too much about it.
Postby iOnic » Mon May 06, 2013 7:10 pm
There's nothing wrong with it. That's normal.
Postby 85AW20v » Mon May 06, 2013 10:32 pm
You could try it again with the handbrake on a couple of notches for a few minutes to give it some load.
See ya
Simon
85 MR2 20v
85AW20v
Postby kim0663 » Tue May 07, 2013 3:17 pm
They are noisy, full stop. Just blocked out inside the car when driving. Even brand new cars would be noisy if chucked on a hoist and ran through the gears 8)
Mr2 GT-S
330ci M
kim0663
Postby allencr » Tue May 07, 2013 7:32 pm
Make any rumbling or whirring when idling in neutral, that disappears when disengaged- clutch pushed down?
Any noise disappear if you move the clutch fork a few mm?
allencr
Postby Boost_4_Life » Tue May 07, 2013 8:58 pm
BHG
'83 KP starlet rally car, 20v powa!
The rally beast
The rally beast again!
Boost_4_Life
Postby MrOizo » Tue May 07, 2013 11:02 pm
Like i said on SCONZ, people fizz over the Royal Purple stuff for the V160's so must be OK for W series boxes.
STA Parts out the airport have this for about $18-$20/litre... at least was when i got my stuff about 4 years ago!
http://royalpurpleconsumer.com/product- ... sion-fluid
MrOizo
Toyspeed Legend
Postby RobertC » Wed May 08, 2013 12:05 am
MrOizo wrote:Like i said on SCONZ, people fizz over the Royal Purple stuff for the V160's so must be OK for W series boxes.
now $31.22 per 946ml.
STA link[/url]
MRAE111 wrote:ok thanks guys but wen u dont have trmpets i think the air flow quickeer into the throttle bodies
RobertC
