Cynos B / 5E-FHE HT leads - expensive ? Alternatives ?
Postby markoneswift » Wed Jun 26, 2013 2:19 pm
Hi all,
I've discovered that I've got a severely corroded coil lead on my Cynos B and after making some calls, it seems I can only get a full set of replacement leads and the cheapest option is $220 !!!! This seems pricey to me, but is it because they are unique to that engine ( they have the little grey clips / plugs ) ?? Are there any cheaper options ?
markoneswift
Postby loose_unit » Wed Jun 26, 2013 2:32 pm
viewtopic.php?t=66290
Have you tried Mark for a price? Unless theyve gone up even the TRD leads were cheaper than that.
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
Postby markoneswift » Wed Jun 26, 2013 2:51 pm
loose_unit wrote:http://forums.toyspeed.org.nz/viewtopic.php?t=66290
Thanks for the quick reply mate and I have tried Toyota direct - they do not have any in Auckland or Hamilton and they're asking $397 + GST !!!!
markoneswift
Postby markoneswift » Wed Jun 26, 2013 2:53 pm
When I take a trip to pick-a-part for my intake hose ( not paying $90 for a rubber tube ), I will see if there are any ignition components I can hoard - there must be loads of Tercels / Corollas with the 5E-FE / FHE that have still got leads on them, dizzy caps, coils etc. Might gather a few spares !
markoneswift
Postby siren676 » Wed Jun 26, 2013 3:38 pm
IIRC I got a full set of clip type ones from repco for under $100
siren676
Postby markoneswift » Wed Jun 26, 2013 3:42 pm
siren676 wrote:IIRC I got a full set of clip type ones from repco for under $100
Did that include the coil lead cos it's the coil lead I really need !! Apparently, the set at $220 is the four plug leads and does NOT include the coil lead !!!!!!!
markoneswift
Postby siren676 » Wed Jun 26, 2013 3:45 pm
Can't remember.
Hmm maybe see if they have any generic length spark leads that could be suitable
siren676
Postby markoneswift » Wed Jun 26, 2013 4:09 pm
Found some at Repco Grey Lynn for $155 including so they're on the way to me now - thanks for the tip mate
markoneswift
Postby markoneswift » Wed Jun 26, 2013 6:51 pm
Coil lead fitted and working awesome - power delivery seems smoother now and throttle response better. I think the old cable must have been really bad. I'll swap all the plug leads over at the weekend - may as well since I had to buy them !
markoneswift
Users browsing this forum: Bing [Bot] and 48 guests
