It has been apart before, I had to rotate the housing 180 degrees from factory when I got it.
Even with the bolts done up motherfuckingtight I can still rotate the bearing housing in the exhaust housing and wobble it a tiny bit.
All the black is from the exhaust leak.
Should the triangle washers be flat? They are ever so slightly not flat, could they be upside down and not clamping the housings together hard enough?
Should there be a sealant maybe?
It's a real bitch taking this off and putting it back on, so I kinda only want to fix it once.
