Coolant temperature
Coolant temperature
Postby mega4a » Mon Jan 13, 2014 8:55 pm
hey guys i was doing some data logging and i noticed my coolant temperature was reaching about 90 degrees c.
i am running a civic radiator. and a Tridon High flow Thermostat.
i was just wondering is this normal ? what is normal operating temp for a 4age turbo ?
also i was getting high air intake temp i thought anyway. what intake temp have other setup on here run at on a normal sunny clear day?
i was getting intake temp of 32 degrees c driving normally but at idle would go up to 36 degrees c
DAILY DRIVEN.
230HP ATFW AE100 WAGON 4AFTE MEGASQUIRT.
1999 Toyota Corolla BZ Touring wagon 4age 20v bt.
1996 Toyota Truneo 5AFE
mega4a
Re: Coolant temperature
Postby 1I1 » Mon Jan 13, 2014 9:00 pm
I see about 85degrees normally on an NA 20v. In traffic as high as 90 - though has been as high as 95 sitting in the pits at the track idling.
TRD Clicky >>Here
1I1
Postby Grrrrrrr! » Mon Jan 13, 2014 9:01 pm
tridon.. lol.
also where were you measuring the temp? and a steady 90*?
Grrrrrrr!
Postby mega4a » Mon Jan 13, 2014 9:15 pm
Grrrrrrr! wrote:tridon.. lol.
whats wrong with tridon?
i am measuring the temp on the thermostat housing where the standard sensor goes using standard sensor hooked up to megasquirt. and it went up to 90 when i was stopped at a light. when i would drive off it would go down to like 88 89.
DAILY DRIVEN.
mega4a
Postby Grrrrrrr! » Mon Jan 13, 2014 9:30 pm
mega4a wrote:whats wrong with tridon?
Well known for being shite thermostats. Personally i've had 50% fail out of the box, (okay, thats only one failed and one okay) other have reported similar (search tridon on the forum). Now I buy genuine, since they are only a few $ more and never had a problem.
90* sitting at lights is nothing to worry about, not hot enough to turn the fans on. And megasquirt calibration might be a degree or two off.
Grrrrrrr!
Postby strx7 » Mon Jan 13, 2014 9:40 pm
90 degrees is very average, possibly even a fraction on the low side.
Postby iOnic » Mon Jan 13, 2014 9:41 pm
90 is fine.
36 is fine.
Postby mega4a » Tue Jan 14, 2014 7:38 am
[/quote]
90* sitting at lights is nothing to worry about, not hot enough to turn the fans on. And megasquirt calibration might be a degree or two off.[/quote]
fair enough. interesting ill have abit of a read of the forum.
DAILY DRIVEN.
mega4a
Postby mega4a » Tue Jan 14, 2014 7:52 am
the hole reason i am asking bout this is because
The other day i was running no intake pipe from my turbo and when i was driving round i noticed much cooler coolant temps could my turbo intake pipe be sucking in hot air from engine bay making the motor generally hotter? . i will take intake off and take a data log to confirm this.
but i was thinking of making a cold air box for my turbo intake... i know there is a lot of controversies about this even mighty car mods did a thing.
i was wondering what you guys thought.
DAILY DRIVEN.
mega4a
Postby Stealer Of Souls » Tue Jan 14, 2014 1:24 pm
Preventing hot air from getting to your intake would seem like a wise idea for any car.
Used to see alot of "cold air boxes" that were a joke, as the pick up for the box was still somewhere relatively hot!
Unless general opinion has changed since I last bothered to read about this stuff. A cold air box with a generously sized cold air feed is a good idea. But you must make sure that it is sealed off from the hot air sources and that you've done your best to prevent the box from heat soaking.
If you can data log, then that'll provide you the best answer. Nothing beats first hand experience with good data.
'86 AE85.5 Levin
Stealer Of Souls
Postby iOnic » Tue Jan 14, 2014 1:44 pm
Cold air intake on a turbo is basically a waste of time IMO
Postby mega4a » Tue Jan 14, 2014 3:52 pm
reviewing the data logs of both times running with intake pipe on and without,
my conclusion is that the results were the pretty much the same.
it just took longer for the car to warm up with no filter as there was more fresh air getting to turbo but once it got to it operating temp the air intake temps and the coolant temps were the same with or without the intake pipe
DAILY DRIVEN.
mega4a
Users browsing this forum: No registered users and 33 guests
