Diff servicing/rebuild Auckland
Postby theDiff » Sat Dec 28, 2013 10:52 pm
So I think my Runx Z diff needs some love - still getting a bad wurrrrring noise on deceleration in 4th/5th/6th gear. From what I have researched it could be the pinion bearing or perhaps another bearing in the diff. I know it's not the tranny or clutch or pulleys because they have all be checked/replaced. So it has to be the diff. Anyone know any good Auckland specialists?
theDiff
Re: Diff servicing/rebuild Auckland
Postby steroidcontaskie » Sun Dec 29, 2013 12:17 am
Steelie gears in otahuhu is good and well priced.
Science never sleeps...
RVR Turbo (idle)
steroidcontaskie
Postby matt dunn » Sun Dec 29, 2013 10:02 pm
What sort of clutch plate does it run?
Postby AE25 » Tue Jan 14, 2014 9:10 pm
is this the same bearing issue that 5speed corolla fielder wagons have?
E2 & E7 fanatic
'71 ke26 '75 KE25 SR 4AGE '78 bug KP60 '83 KE70 SR Coupe 3TGTE '84 ke74 '84 ae85.6 trueno '84 YN57 SR5 '86 AE82 FXGT 20v '91 ST185 '92 SW20
http://www.toycrazy.net
AE25
Postby theDiff » Wed Jan 15, 2014 5:03 pm
Nope - it's not a bearing issue. All bearings have been replaced (not cheap) and the noise remained. But the chaps at Gearbox Factory figured it out!
I got the car with a heavy duty clutch that had a solid brass center (previous owner installed it for whatever reason) and unknown to him, when installing a clutch of this type in certain vehicles, there can be an increase in transferred harmonic noises from the engine to the gearbox. This may also cause gearbox rattle - particularly on decel.
These transmitted noises in no way affect the performance of the clutch or the vehicle, and is widely accepted in the performance industry, where engine and/or clutch modifications have been carried out. So there you go!
I'm getting a heavy duty center with duel springs put into the OEM clutch which will make it much quieter.
theDiff
Postby matt dunn » Wed Jan 15, 2014 10:24 pm
I have struck that too with solid centre clutches, that's why I asked.
Glad to know it was not diff issue.
Postby theDiff » Thu Jan 16, 2014 9:40 am
What solution did you come up with that worked - if anything?
theDiff
Postby 1I1 » Thu Jan 16, 2014 9:52 am
It's come up on here a couple of times and OEM clutch has removed the noise.
TRD Clicky >>Here
1I1
Postby theDiff » Thu Jan 16, 2014 2:04 pm
I put an OEM in and it did nothing so the gear box factory lads put a heavy duty plate in and they believe it's worked. Horses for courses I guess.
theDiff
