V-Bands in exhausts
V-Bands in exhausts
Postby 1I1 » Thu Jan 23, 2014 12:32 pm
Looking at remaking part of the Corollas exhaust and want to include a join - have two options to use a normal bolt together flange or go for a v-band.
Wondering how people have found them? The join will be about 3/4 of the way down the exhaust and there is probably going to be a bit of twisting force applied to it due to the exhaust layout
If going v-band, probably going with:
http://dsrturbo.com/exhaust/v-band/2.5.html
TRD Clicky >>Here
1I1
Re: V-Bands in exhausts
Postby Stott69 » Thu Jan 23, 2014 2:30 pm
Personaly I think they suck n leak. But that might just be me. they seem to be a pain on some of my joins, but the two forged ones on the W/gate are good.
Stott69
Postby iOnic » Thu Jan 23, 2014 2:57 pm
Can't go past them but you need good alignment. They'll leak if your pipes aren't aligned.
Most new trucks only run V band joins.
Postby Mr Ree » Thu Jan 23, 2014 8:01 pm
I fcuken LOVES v bands.
Alot of the cheaper ones leak, because they are slightly untrue, but Mark, I would just do it, and spend the time to get it aligned just right so it does not leak. You will never look back.
Im seriously thinking about buying the option v-band inlet rear housing for the 6266. I need to decide before getting the manifold built for it, but it seems like a no brainer to me. 2 minute turbo removal, here we come ;)
wak thud gush!
Mr Ree
Postby wde_bdy » Thu Jan 23, 2014 8:20 pm
Last exhaust I got made was just slip jointed, good amount of overlap and good clamps and no leaks.
Callum
wde_bdy
Postby touge_ae101 » Thu Jan 23, 2014 8:42 pm
Yeah v bands are fine as long as it is all aligned properly and the two faces are parallel.. Generally most exhaust flange leaks are related to poorly aligned exhausts or not enough mounting points. If you're worried about leaks just add a few more mounting points
touge_ae101
Postby evil_si » Thu Jan 23, 2014 9:06 pm
I use a lot of v bands, and always face them after welding to ensure they are still flat,
evil_si
Postby Stott69 » Thu Jan 23, 2014 9:22 pm
evil_si wrote:I use a lot of v bands, and always face them after welding to ensure they are still flat,
Could I ask how? Any special tools?
Stott69
Postby Crucible » Thu Jan 23, 2014 9:48 pm
alot of sealing problems Ive found are from how they are welded in to start with..
Generally if they are tacked then taken apart and welded in fully the heat will twist and move the bands off centre so they wont seal properly. I weld them in fully clamped then destress the pipe either side if the joint with gas/heat if i can to take any twisting stresses out of the joint, seem to seal ok that way.
Crucible
Real Life Mechanic
Postby Crucible » Fri Jan 24, 2014 8:39 am
Sharp bastard or flat file.
As long as you take your time and keep the file flat on the work, I have gas cut turbo flanges in the past and dressed the surface up this way. Seal up fine.
Crucible
Real Life Mechanic
Postby Bazda » Fri Jan 24, 2014 11:04 am
They are great to take ex on and off.
after welding they need to be linished flat.
Belt sander is what I use that has a flat table on it.
Postby evil_si » Sat Jan 25, 2014 7:39 pm
Fu#k using a file
I use a bench mounted linisher as Barry said.
I've also seen guys use a cheap belt sander from Bunnings mounted in a vice with good results
evil_si
Postby XSVWGN » Sun Jan 26, 2014 12:11 am
I love them. They make things easy as!!!
2008 Kia rio - work car
XSVWGN
Postby Crucible » Sun Jan 26, 2014 12:16 pm
evil_si wrote:Fu#k using a file
It does sound a bit sketchy I know, but is quite achieveable if you take your time and KEEP it flat, not swinging off it etc. More of a case of using what you have, not saying it's the best or quickest way.
Beltsander would be better...if you have one.
Crucible
Real Life Mechanic
Postby evil_si » Mon Jan 27, 2014 8:37 am
Haha i was referring to how long it could take to file a stainless v band,
I dont use files anywere near as much as i use to / should
evil_si
Postby Crucible » Mon Jan 27, 2014 10:53 pm
I sorta guessed thats what you meant..
Yeah have to admit my files dont get much use, thank f#ck for carbide burrs.
Crucible
Real Life Mechanic
Postby ch4ng » Tue Jan 28, 2014 5:14 pm
Go for it! it turns any exhaust removal into a piece of cake and no having to deal with siezed bolts in tight places. I'll never go back.
Chondah Civic
2T Navara
ex:
Charade Detomaso
MX5 - Stancemobile
MX5 turbo - El Tigre
87 Alto - The Tragic 3cyl powah
AE111 BZ-G Death Race 15.09
No Limits Onsite Paint Repairs. Cut and polishing, stone chip and scratch repairs. 021-177-8539 Mention Toyspeed.
ch4ng
Users browsing this forum: Bing [Bot], Google [Bot] and 10 guests
