Insulating material
Insulating material
Postby Mr Revhead » Wed Jun 18, 2014 1:51 pm
I need to insulate the intake manifold from the cylinder head. Steel head, alloy manifold and the heat transfer into the manifold is shocking! Stopping that transfer would lower my intake temps quite a bit I think.
So, I want to make up a thin sandwich plate to go between the two. Moving the manifold out 10mm or so won't matter, I will just extend the top intercooler hose to make it up.
Any one have any ideas of what I can use to make it?
Re: Insulating material
Postby Bling » Wed Jun 18, 2014 2:01 pm
Some tin covered in that gold foil Bazda sells?
Postby whynot » Wed Jun 18, 2014 3:12 pm
Gold foil would be good for radiant heat not conducted heat. There are thermal gaskets on trade me which some suppliers could make to order. Usually made of a solid plastic or similar.
whynot
Postby JZCrazy » Wed Jun 18, 2014 9:23 pm
Have got one of those Gizzmo thermal gaskets on the 1JZ, don't ask me if it works cos I don't know.
The radiant heat is a problem, hot days etc.
JZCrazy
Postby Bling » Wed Jun 18, 2014 9:35 pm
whynot wrote:Gold foil would be good for radiant heat not conducted heat.
I somehow misread his post, you're right it would be no good. :oops:
Postby Mr Revhead » Wed Jun 18, 2014 9:36 pm
Shit, I was really looking forward to blinging it up!
Postby limbo » Wed Jun 18, 2014 9:39 pm
I emailed Gizzmo a while ago about them making me a thermal gasket, they said they would make one if I sent them a cad file of what I wanted. I made the file just haven't sent it to them yet. Dang that was 8 months ago...
Lance Streeter <nzsales@gizzmoelectronics.com>
limbo
Postby gepsk8 » Wed Jun 18, 2014 10:41 pm
Gizmo gasket work great, got one on my corolla. Drop temperature by 30degrees. Can now touch inlet manifold after driving.
O272754663
gepsk8
Postby Mr Ree » Wed Jun 18, 2014 11:51 pm
Yes, the phenolic gaskets have been well proven to drop IM temps, so a worthwhile investment for anyone suffering from terrible heat soak.
And making a heat shield out of that ACL formable heat shielding, then covering it in the gold reflective material will help too.
wak thud gush!
Mr Ree
Postby Mr Revhead » Wed Jun 18, 2014 11:53 pm
Cheers guys, will look that up.
Yeah I've got a heat shield between the turbo and i/c. That made a huge difference!
Postby GDII » Thu Jun 19, 2014 10:59 am
gepsk8 wrote:Gizmo gasket work great, got one on my corolla. Drop temperature by 30degrees. Can now touch inlet manifold after driving.
When you say 'after driving' what do you mean? I don't have a plastic spacer on my car (bone stock engine) but when I have just finished driving I can touch my intake manifold just fine. After a few minutes it gets heat soaked and I can't touch it. I put this down the air flow through the manifold but when the engine stops drawing air through it, it just absorbs the heat from the engine.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby Mr Revhead » Thu Jun 19, 2014 11:02 am
In my case, 4JB1-T Isuzu the I/c is cool to the touch, and the manifold is hot. The closer to the head you touch the hotter it is.
On my old AW11 s/c with a Subaru w2a I/c the intake would be cool after a drive.
Postby gepsk8 » Thu Jun 19, 2014 12:54 pm
If I take my car for drive for over 30mins, then pull over the side of road pull your hand on inlet manifold, use it support yourself as look at rear of engine bay. You won't it to hot. As mine is not as hot. Was 30 degrees different with heat gun.
O272754663
gepsk8
Postby whynot » Thu Jun 19, 2014 1:31 pm
I dont have a thermal gasket on my corolla as the throttles have a plastic gasket from the factory but I covered the plenum with refrigeration insulating foam to try and keep the heat out. When im driving the air temp is normally less than 4 deg above ambient and it takes a 30min drive from cold before the w2a cooling system even starts to warm up.
whynot
Postby jondee86 » Thu Jun 19, 2014 8:36 pm
The BEST thermal gasket material is pure virgin teflon (PTFE). Bit
spendy though... I got two head/manifold gaskets waterjet cut from 1/8"
thick teflon and from memory they cost over $100 each... and I got a deal
on the teflon !! Phenolic is a cheaper option.
Thermal gaskets work by slowing down the rate of heat transfer from the
head to the manifold. So heat flow into the manifold is reduced, but heat
transfer away by the intake air remains the same. Thus, the equilibrium
temperature of the manifold is lowered.
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby evil_si » Thu Jun 19, 2014 9:05 pm
Send our cad file to one stop cutting and get them to quote supply and cut, They will have something suitable in stock
evil_si
Users browsing this forum: No registered users and 38 guests
