altezza etsc fuse blows? Doesn't start?
Postby TRD_ZERO » Thu Oct 02, 2014 5:35 pm
I recently bought an altezza. Now my problem is when i connect the battey the hazards stay on, dont flash just stay illuminated. I have no dash lights nothing works. Also found the etsc fuse was blown it blows everytime i connect the battery. Picked it up drove around for a few days no problems. Thought I'd give it a nice clean while having the stereo on for and hour or so but then it died. Battery was flat so put it on charge. Left the car outside for a few days. Tried putting the battery back and Etcs fuse blows and hazard lights stay on. Could the alarm be doing something to it? Anyone have any ideas?
Previous:
TRD_ZERO
Re: altezza etsc fuse blows? Doesn't start?
Postby rollaholic » Thu Oct 02, 2014 7:25 pm
got the battery back in the right way round / right terminals on appropriate leads?
Postby TRD_ZERO » Thu Oct 02, 2014 8:11 pm
Nice problem solved! Someone has aftermarket power and earth leads on it so can't distinguish the colours. Can't believe I didn't think of that. :oops: Thanks
Previous:
TRD_ZERO
Postby 85AW20v » Thu Oct 02, 2014 10:13 pm
About time to put some red tape on the positive lead?
See ya
Simon
85 MR2 20v
85AW20v
Postby TRD_ZERO » Fri Oct 03, 2014 9:30 am
85AW20v wrote:About time to put some red tape on the positive lead?
Yup won't be making that mistake again.
Previous:
TRD_ZERO
Postby RS13 » Fri Oct 03, 2014 3:09 pm
You're lucky that all you blew was a fuse.. I've seen that mistake destroy cars.
RS13
Postby TRD_ZERO » Fri Oct 03, 2014 5:38 pm
Yeah well i guess that isnt the end of my horrible story. Im getting a leak coming from the gearbox from the front now. Looks to have blown the 120amp fuse with this whole situation but the car would start and drive but didnt shift well once that fuse was changed the car runs normally but leaking out the gearbox now. what could have given way around the front of the gearbox to cause the leak any ideas as i havent had time to check. Looking back at this makes me think i shouldnt be touching it. Ive got a feeling ive damaged something on the gearbox causing it to leak.
Previous:
TRD_ZERO
Postby matt dunn » Fri Oct 03, 2014 11:21 pm
the 120A main fuse blown means that more than 120A has gone through something backwards.
I would say your alternator is also stuffed.
The other thing we see often when cars are jump started backwards is a stuffed radio.
Postby rollaholic » Sat Oct 04, 2014 10:07 am
whats the leak? (ie what kind of fluid) if its coming out from between the engine and the bellhousing it could be the rear main seal, or it could be something leaking onto the bellhousing from above and running through it. or it could be the front seal on the gearbox input shaft.
plenty of options really :)
Postby TRD_ZERO » Sun Oct 05, 2014 6:24 pm
Correct stereo says no. Not too fussed about that though. Altenator still works so thats good for now. The oil falls on the exhaust and and smoke smells weird like nothing ive smelt before. Unless the burt oil burning outside of the combustion chamber smells different to oil burning inside of the combustion chamber because i know what that smells like. I smelt the dripping oil and im pretty sure its gearbox oil. The weather has been pretty bad this weekend so havent had a chance investigate any further.
Previous:
TRD_ZERO
