AE111 BZG heater issue
Postby JT » Mon Mar 23, 2015 1:03 pm
AE111 BZG
The aircon works fine through the whole heat range but with the aircon turned off the air coming out is warm/hot even on the coolest setting.
This happens when the fan is turned on. It also happens when the fan is off and fresh air setting is selected.
My wife got around the problem by using the air con or selecting re-circ when fan not needed.
Haven't had to fix a heater so I'm not sure where to start or what order to attack it.
JT
Re: AE111 BZG heater issue
Postby MAC_HATER » Tue Mar 24, 2015 9:45 am
easiest check would be to see if the actual heater tap that opens\closes when you adjust the in cabin slider switch, and see if it is jamming or binding before fully closing, hopefully if should be accessible near the firewall in the engine bay
otherwise the other problem is the actual control unit in the dash, my one needed dry solder joints re-flowed, and even the tracks could be worn and not actually registering you wanting to close the loop for cold air, if you can track down a known good replacement to at least plug in and try and see if that also helps
~SlideWays~: Cars + Males = Single, therefore: Poptarts?
MAC_HATER
Postby matt dunn » Tue Mar 24, 2015 11:34 pm
Does it have climate control as the problems can be different for ones that do and dont.
By climate control I mean is there temperature numbers on the hot cold slide?
Postby JT » Thu Mar 26, 2015 7:48 pm
matt dunn wrote:Does it have climate control as the problems can be different for ones that do and dont.
Yes it does have the numbers along the temp slide. How does that affect things?
JT
Postby RobertC » Thu Mar 26, 2015 10:53 pm
Try inspecting the back of the controllers circuit board. (needs removing and disassembling/) I have had problems with them in the past (fan speed changing on its own, heat not going hot cold as its supposed to)
There were a few dry soldier joints dry soldier joints on the circuit board, a few dabs of soldier and they were good as new.
Assuming your controller looks like this
MRAE111 wrote:ok thanks guys but wen u dont have trmpets i think the air flow quickeer into the throttle bodies
RobertC
Postby matt dunn » Fri Mar 27, 2015 12:33 am
Then the temperature is caluclated and so to get the temp part to work properly you need
the inside temp sensor,which is is a wee vent on the panel under the steering column,
and the outside temp sensor which is in front of the radiator
both must be connected for correct temp control otherwise the temp will be very erratic
and may not go hot, or not go cold.
Postby sergei » Fri Mar 27, 2015 8:45 am
I had similar issue in AE101 when the cabin temperature sensor got disconnected. only two temperature settings as effect of the fault: coldest setting would result in cold, and anything else in hot.
In AE101 the cabin temperature sensor is below the steering wheel (slighlty to the left) in the panel that also houses the bonnet release lever (opposite side of the sensor).
