front rotors
front rotors
Postby zimmy » Mon Jun 01, 2015 3:21 pm
hi I have a 2007 Toyota blade 3.5 v6 gre156 the oe number for the front rotors is the same as rav4, I am after some slotted rotors for the blade, it appears that the camry/aurion/rav 4 front rotors are the same but the camry/aurion are a different part no can anyone confirm if they are the same rotors as there is no listing for a blade. disc dimensions are 296mm 28mm thick 49.3 height 5x114.3 62mm centre hole.
hope someone can help.
cheers don
zimmy
Re: front rotors
Postby wde_bdy » Mon Jun 01, 2015 4:00 pm
DBA2705 should be the right number.
Lexus ES300 MCV30 (01 onwards)
Camry MCV30 (01 onwards)
Estima ACR30 (03 to 06)
DBA2709 is another possibility.
Camry ACV40R (06 onwards)
Aurion GSV40R (06 onwards)
I just ran those dimensions through the DBA catalogue, difference between them is 2705 has 26mm min thickness and 2709 is 25mm. There is also 2712 from the Lexus RX300 but the height is 49.5mm. This is an Oz catalogue though so there may be other options. Have a dig through the online brembo catalogue for more detailed dimensions.
http://www.bremboaftermarket.com/En/Car_Disc_Catalogue/Catalogue_Detail.aspx?ApplicationIDMaster=365020
Pic of BDA2709 equivalent.
Callum
wde_bdy
Re: front rotors
Postby zimmy » Thu Jun 11, 2015 11:24 pm
guys at znoelli hooked me up with dds sport rotors for front and sp500 pads front and rear. same rotor as camry and aurion. leaving stock rotor in rear.will see if it improves car.
Donald
zimmy
