st215 drama
st215 drama
Postby Jingle Balls » Mon May 25, 2015 1:11 am
Hi there
I've done as much research as I can with no definitive view on what should be done for my auto 97 caldina gtt issue.
The issue:
It seems when rpm goes above 2000 for a few seconds, it throws CEL and VSC lights and will not shift from 3rd.
My search:
It seems there is a common fault with the dash cluster in these cars that cause an issue with the VSS that generates similar symptoms (but not quite the same) so I will look into that, however the speedo always works fine so it doesn't seem like this issue?
I've tried using my OBD2 scan tool to check the code, but this car doesn't seem to be compliant. On searching how to check the codes, I can't find any info on how to physically retrieve them, other than what the codes are
Any help is appreciated
Jingle Balls
Re: st215 drama
Postby Stu- » Mon May 25, 2015 1:24 pm
Yes it will more than likely be the faulty track inside the gauge cluster - had the same with mine.
Project Thread
Stu-
Re: st215 drama
Postby Jingle Balls » Tue May 26, 2015 11:45 am
I've located the common fault chip and there is nothing wrong with the solder, it looks perfect. will continue to look into this further, any help would be appreciated
Jingle Balls
Re: st215 drama
Postby Stu- » Tue May 26, 2015 11:58 am
The old fashioned way of getting codes with Toyota ecu is to bridge te1 and e1 on the diagnostic plug. I had a 97 gtt and the scan tool worked fine on it for some reason
Project Thread
Stu-
Re: st215 drama
Postby Jingle Balls » Tue May 26, 2015 12:09 pm
Great thanks. I might buy another scanner and try that
Jingle Balls
Re: st215 drama
Postby fivebob » Tue May 26, 2015 3:40 pm
Some scan tools work, most don't. Easier to bridge the TC & CG pins on the connector for ECU codes (IIRC it's pin 12 & CG for ABS codes)
Re: st215 drama
Postby Jingle Balls » Wed May 27, 2015 11:57 am
Thanks I will do that as the cheap Bluetooth one I just bought also doesn't work.
After reassembling the gauge cluster, the VSC light now comes on straight away rather than once the check engine light does. Given the only things to be touched, I'm thinking the problem either is in the gauge cluster inspite of the appearance of good condition, or the dash wiring harness
Jingle Balls
Re: st215 drama
Postby Stu- » Wed May 27, 2015 1:14 pm
It was a faulty track in mine, no visual give away, just bad connectivity when testing with a meter. I just soldered on a bridge wire - job done.
Project Thread
Stu-
Re: st215 drama
Postby Jingle Balls » Thu May 28, 2015 12:19 pm
That's great info thanks. I might buy another cluster to use for parts/testing
Jingle Balls
Re: st215 drama
Postby Jingle Balls » Fri May 29, 2015 11:15 pm
New cluster didn't help, maybe it has the same issue. Bollocks.
Without throwing more unnecessary parts purchases at it, I better find out how this vss system works.
My questions are now:
Which wire in the harness is the vss? Does the sensor send a voltage or resistance to the dash cluster and what is the expected range? How does it then get to the ecu? Where is the sensor(s)?
Jingle Balls
Re: st215 drama
Postby Jingle Balls » Sat Sep 12, 2015 11:47 pm
For anyone in the future that searches the symptoms and finds this thread, the knock sensor had failed
Jingle Balls
Re: st215 drama
Postby Dell'Orto » Sun Sep 13, 2015 11:12 am
Thanks for that, always good to hear the resolution!
