JZX100 Chaser manual rear subframe removal
Postby KIPH8N » Tue Aug 02, 2016 12:05 pm
Hi guys,
I recently imported a jzx100 manual chaser.
So when it got here i saw that the diff bush's are cracked. I'm thinking of removing the rear subframe myself (home garage) and changing the diff bush's.
I have done a bit of research and found out that i can replace them with solid weld bush's/ KTS solid bush.
Would i need to buy rubber bush with the solid bush or can i use just the solid bush by itself.
Are there anything else i should change while the subframe it out?
Car is still not complied or certed. Would these solid bush pass cert and compliance?
Previous:
1991 Levin GT Apex (SS) Manual
1991 Levin GTZ (SS) Manual
1995 Toyota Levin BZV (SS) Manual
1997 Toyota Corolla BZ Touring Manual
1998 Trueno Bzr SS to Mcpherson 4agte
1997 Toyoya Chaser 1jzgte Factory Manual ;)
1998 Nissan Primera Autech SR20VE
Contact 0211779879
Email nameetn@hotmail.com
Facebook: Navneet Nand
KIPH8N
