What bell housing is this ??? ROUND TWO !!!
Postby jondee86 » Fri Sep 22, 2017 4:10 pm
Can anyone identify what engine this bell housing would have come from ? It fits the
early 20-spline T-50 with 62mm dia input shaft bearing, but it does not bolt to A-series.
I've goooooogled my ass off, but can't find anything that matches this. Ot did come to
me with a DIY cable shifter conversion bracket bolted on, but I'd say it was from a car
with hydraulic clutch. The only markings anywere are "3-1" in one of the pockets on the
gearbox mounting face.
Cheers... jondee86
Watch this space >>> <<<
jondee86
Re: What bell housing is this ???
Postby jondee86 » Sat Sep 23, 2017 12:05 pm
Got it sussed after a bit more looking on the interwebz. It's a T-series bell so maybe
useful to someone. If that's you... let me know :)
Cheers... jondee86
jondee86
Postby Celica RA45 » Mon Oct 23, 2017 12:24 am
could be a 1s bellhousing looking at it
Celica RA45
Re: What bell housing is this ??? ROUND TWO !!!
Postby jondee86 » Mon Oct 23, 2017 12:48 pm
I.ve got another bell housing to try and identify. This one is proving to be more
difficult to figure out...
The bell has been mofified with a steel plate to match a different gearbox. Going
by the bolt pattern I would guess a W50. A window has been opened up in the side
to accommodate athe clutch fork. The bell looks a little bit like a 4A but it seems
to be a bit smaller and definitely won't fit a 4A.
So if anyone recognises their handiwork or can tell me what engine this this bell
was originally fitted to, I would like to know :)
Cheers... jondee86
jondee86
