diff uprade for ae86
Postby JustinSpiderholden » Thu Oct 13, 2005 3:46 pm
hey is it possible to put a supra celice diff into a ae86 as i think these would make a better upgrade than a hilux diff as you can still purcashe the trd lsd 4 them
JustinSpiderholden
Postby Low_Aa63 » Thu Oct 13, 2005 3:50 pm
as far as my knowledge extends the supra g series lsd internals will fit in the g series hilux rear. + goodluck putting irs into an ae86!
The best option would be hilux rear with a locked diff! no mucking round with lsd's and both wheels going all the time!
The list so far
Te71, Ae82, Ke70x2, Mx73x2, Ga61, Gx61, Ra63, Aa63, Ae70, Ae85, Ke25, Ke30, Ke36, Gz10x2, Hb11, Ta40, Ma45......
geishaboy wrote:I want a number plate with "geisha" on it
But I should probably get a car first
Low_Aa63
Postby SLIDE_WAYS » Thu Oct 13, 2005 3:50 pm
Ok AE86 have a T series live rear end and a celica supra has a T series independant or an F series independant.
What celica supra are you talking about???
F Series is way bigger but like I said I have only ever seen them as independant rear.
S13 Silvia - Stroked CA18DE With 4 Throttles
83 Cosmo - 12AT Running 17 Pound.
MA61 Supra - Manual + HKS Cams and Exhaust
AE101 Levin - Foxtons Kit, Stage 2 Cams
AE86 Levin - Check My Page
SLIDE_WAYS
Postby Low_Aa63 » Thu Oct 13, 2005 3:52 pm
ahh but you can get f series live rear axle they come in 1980's gt corona's ussually in the factory 18r ones and generally in the liftback!
The possibilities for f series live conversions are there but goodluck finding one!
The list so far
Low_Aa63
Postby SLIDE_WAYS » Thu Oct 13, 2005 3:54 pm
like you had man I know where you live and you know where I live
JONES AFTER WORK MY PLACE CAN YOU GUESS WHO THIS IS
SLIDE_WAYS
Postby spencer » Thu Oct 13, 2005 3:55 pm
I have seen a F series solid axle just have to hunt around one. As for the trd lsd worries about that shimmed hilux lsd will do the trick easy in the old ae86
spencer
Postby Low_Aa63 » Thu Oct 13, 2005 4:00 pm
ahh but when it comes to f series lsd on the irs if you didnt get one factory... you WONT get one after market!
The list so far
Low_Aa63
f series is 7.5inch it will handle the power!
The list so far
Low_Aa63
Postby Low_Aa63 » Thu Oct 13, 2005 4:01 pm
SLIDE_WAYS wrote:like you had man I know where you live and you know where I live
is jones over??
The list so far
Low_Aa63
Postby SLIDE_WAYS » Thu Oct 13, 2005 4:01 pm
work is work if your changing the diff do it once and do it right.
What power were you thinking of running???
Hilux rearend behind an N/A 4AGE sounds ummmm over doing it a tad
SLIDE_WAYS
Postby spencer » Thu Oct 13, 2005 4:05 pm
Low_Aa63 wrote:ahh but when it comes to f series lsd on the irs if you didnt get one factory... you WONT get one after market!
altezza is F series irs so looks like you can get f series factory lsd still. Trd do a LSD for altezza aswell they swap onto a solid head with abit of playing. Also hilux is overkill but t-series will still break behind a na 4age if doing skids
spencer
Postby Low_Aa63 » Thu Oct 13, 2005 4:08 pm
the only thing similar between f series irs and independant is the crown and pinion wheel size! the spider casing/lsd clutches/whatever you put in there is not the same and will not fit! Irs being the bigger one ofcourse!
The list so far
Low_Aa63
Postby SLIDE_WAYS » Thu Oct 13, 2005 4:09 pm
there is no factory LSD head for an f Series live axcel
SLIDE_WAYS
Postby spencer » Thu Oct 13, 2005 4:10 pm
SLIDE_WAYS wrote:there is no factory LSD head for an f Series live axcel
thats not true
spencer
Postby SLIDE_WAYS » Thu Oct 13, 2005 4:13 pm
Well I have yet to see other wise do you have a Toyota Part Number that I could look up I would just be interested in seeing it.
SLIDE_WAYS
Postby spencer » Thu Oct 13, 2005 4:20 pm
Low_Aa63 wrote:the only thing similar between f series irs and independant is the crown and pinion wheel size! the spider casing/lsd clutches/whatever you put in there is not the same and will not fit! Irs being the bigger one ofcourse!
Irs stuff can be swapped im sure many people have done it on here before I have done it with t-series gear. I have a torsion altezza factory f series lsd from a wrecker and the crown wheel swaps over also the axles fit havnt finished yet as its a busy time at uni. So you guys can stow it
spencer
Postby Low_Aa63 » Thu Oct 13, 2005 4:22 pm
I have to aggree with the ke70 dude, that they do i have seen three in my career as a toyota wrecker lol!
But they dont fit in the irs rear and vice versa!
And goodluck finding a part number as i have learnt TRD stoped making F series Lsd's in May.......................................1988
The list so far
Low_Aa63
Postby spencer » Thu Oct 13, 2005 4:29 pm
Low_Aa63 wrote:And goodluck finding a part number as i have learnt TRD stoped making F series Lsd's in May.......................................1988
and shit me they started making them agian 41301-RA010.
spencer
Postby Low_Aa63 » Thu Oct 13, 2005 4:33 pm
for live rear axle....no they didnt.....
The list so far
Low_Aa63
Postby spencer » Thu Oct 13, 2005 4:37 pm
no shit but im trying to swap a live axle lsd over and im almost there and its been done before. read above :roll: this poor guys threads been owned
spencer
Users browsing this forum: No registered users and 22 guests
