Stealer Of Souls wrote:Info's a bit third hand, but I know someone who knows someone who did an external drain... and apparently it was a total pain in the A to do.
It sounds like something is making your problem extra bad. Are the drains in the head particularly scummed up perhaps?
Perhaps run a thinner oil????
Mr Revhead wrote:how about pulling the cam covers off to see if your head is ful lof gunk, gunk can stop it draining back
btw the bigports are well known for filling the head up, hence the small port drain and 20v bigger inhead drains
pc wrote:The head is surgically clean and I can shine a torch down the holes and see nothing.
jondee86 wrote:It would be kind of unusual for the breather to vent directly into the intake manifold. Usually they vent into the ducting upstream of the throttle butterfly, so high rpm shutoff will not draw anything from the cam covers. Venting straight into the manifold will cause your engine to idle funny![]()
Cheers... jondee86
RedMist wrote:My race bigport ran two very large vents (one from each rocker cover) through to a catch can. Apparently (do not quote me on this) the relief of pressure allows the oil to drain back quicker (although I cant see how) It seemed to work on my bigport, I had very little oil collected.
