Boost creep problem - 3sgte
Postby CelicaGT8 » Fri Jan 22, 2010 3:37 pm
I have an upgraded ct26 (ct27) on my 3sgte as showen below.
Very old pic, but you get the idea...
Im using an aftermarket wastegate which i have a 8psi spring in.
However when i floor the car it just boosts to 14psi then hits boost cut (using standard computer) . If i floor it in a higher gear tho, like 3rd when im going 40km it the gate will open as normal then the boost will creep untill it reaches boost cut.
I think this is because the standard internal waste gate that im running my new waste gate from is to small or doesnt get enough flow to it, and it just cant bypass enough air????
Any idea how to fix this bloody problem?
It was fine when it was a standard turbo.
How do you get rid of the boost cut on a gen 2 3sgte?
Thanks
CelicaGT8
Postby JustinSpiderholden » Fri Jan 22, 2010 3:40 pm
You external is pointless if you are feeding it from the standard internal wastegate port, as the flow will still be being restricted by the the size of the standard internal wastegate port
So you need to weld up the stock internal and have the external taking the exhuast gas away before the exhust hosuing, or have the exhuast housing modifyed so that the external waste gate take exhust gasses away directly from the housing
JustinSpiderholden
Postby levinguy » Fri Jan 22, 2010 4:01 pm
wow how many brass t's do you have for your oil pressure sensor/s?
levinguy
Postby Akane » Fri Jan 22, 2010 4:12 pm
You can first try a cheaper fix by porting the internal gate, and see if it improves anything.
Or fix it properly, weld up internal gate, feed the external from the manifold, like everybody else does.
Postby CelicaGT8 » Fri Jan 22, 2010 5:17 pm
Sounds like a lot of effort
Basically just needs a new manifold and dump pipe, no biggy...
You would think that a turbo croud that has done tons of these would tell you that the standard waste gate will be useless after the upgrade.
Iv seen some standard waste gate ports modified with very little gain
its a lot of effort to make another dump and manifold tho, suppose i could run two pipes from each of the enterys to the turbo from the manifold and feed them into the pipe just before the after market waste gate. would there be a problem with back pressure tho?
And those cheap manifolds will be horrible to weld to.
(mr levin guy, like it says, old pic when are you going to race your ga70?)
CelicaGT8
Postby MR2BOY23 » Fri Jan 22, 2010 5:18 pm
Off topic: But did you get your turbo from the states?
MR2BOY23
Postby CelicaGT8 » Fri Jan 22, 2010 5:19 pm
no sent it down to the south island and got it upgraded.
CelicaGT8
Postby strx7 » Fri Jan 22, 2010 9:55 pm
what brand of wastegate is it? also how is it being controlled? where is the boost feed to the wastegate fed from? does it have a massive intercooler?
Postby levinguy » Fri Jan 22, 2010 10:04 pm
strx7 wrote:what brand of wastegate is it? also how is it being controlled? where is the boost feed to the wastegate fed from? does it have a massive intercooler?
its an hks copy wastegate, been fed from straight off the compressor housing as well as the intake manifold with the same results. intercooler isn't that excessive
levinguy
Postby Anth_555 » Sat Jan 23, 2010 10:10 am
dont ct20b and ct26 have this problem becose the watsegate port is to small even porthing it dosnt fix it you have to set it up off the manifold
-1994 GT4 Celica ST205 project
-1984 Trueno AE85
-1993 Surf LN130
Anth_555
Postby sergei » Sat Jan 23, 2010 11:20 am
Anth_555 wrote:dont ct20b and ct26 have this problem becose the watsegate port is to small even porthing it dosnt fix it you have to set it up off the manifold
Yep.
Don't waste your time on porting. Just blank off the original ports, and weld the wastegate port on the manifold (from looking at the pic you already have custom/aftermarket manifold, hence it will be easier to do it.).
Something like this:
Postby CelicaGT8 » Sat Jan 23, 2010 1:41 pm
Thanks for the input guys
I was thinking of welding a pipe from the manifold on the right (in the pic) and link a feed from those two clynders to the pipe from the standard wastegate....
Will that be a problem...?
means i dont have to muk around to much, this project has gone way out of hand, was just suppose to be a 3sge
CelicaGT8
Postby sergei » Sat Jan 23, 2010 10:55 pm
your manifold and turbo is twin entry. which means two pipes + either 2 wastegates or 1 wastegate with separator.
Postby CelicaGT8 » Sun Jan 24, 2010 10:38 am
Yes it should be like that, but would it really matter if i did it that way, i mean it wont be a perfect system, but if it wont damage the turbo or something then why not.
It will still be bleeding some air off from the other 2 clynders through the standard waste gate ports aswell as from more from the manifold to try and get more flow to the waste gate....
Its the easyest way i can think of, but if its going to have negitive effects then i wont do it.
Also, does anyone know how to stop the factory boost cut on a 185 computer
CelicaGT8
Postby JustinSpiderholden » Sun Jan 24, 2010 11:22 am
I'm not 100% sure but doing it the way you intend would make it laggier wouldnt it? as the turboo would bleed excess exhuast gas from one side of the turbine effecting spool
Yes it will still bleed excess from the other side of the housing but the standard internal gate takes exhuast gases both side's of the housing
JustinSpiderholden
Postby Guss » Sun Jan 24, 2010 12:51 pm
I would have thought that bleeding the air from two cylinders only would affect the backpressure of only those two so going to behave differently to other two cylinders possibly leaner due to more scavenge ?
also what happens if the two cylinders not bled provide enough exhaust to still get boost limit.
Wheres steve murch
Guss
Postby CelicaGT8 » Sun Jan 24, 2010 11:00 pm
Well it would be those two cylinders directly aswell as the other two through the standard wastegate ports... im not sure of any negitive eccects... but if there are any that could destroy my engine then please do tell me before i do smthing silly lol
CelicaGT8
Postby Anth_555 » Tue Jan 26, 2010 10:45 pm
on my st205 when i got it i put a external on. had a big hole right through the collector on the stock manifold and never had lag or boost problems at al. that was with a ct20b.
-1984 Trueno AE85
-1993 Surf LN130
Anth_555
over boost
Postby ST205 GT4 NZ New Group A » Fri Jan 29, 2010 1:17 pm
Havn't read the whole thread but do you have an aftermarket down pipe?
if so clearance issues with internal wast gate on downpipe
Re: over boost
Postby Akane » Fri Jan 29, 2010 1:32 pm
ST205 GT4 NZ New Group A wrote:Havn't read the whole thread but do you have an aftermarket down pipe?
well, read the whole thread and see why that isn't an issue.
