Gearbox axle seals question
Postby Akane » Fri Feb 19, 2010 4:12 am
Hi, I am having a bit of trouble with axle seals.
This is a picture of the seals in question
1) Which part of the seal does the actual sealing? The outer raised lip pushing against the surface of the axle? Or the inner circumference pushing against where the spline is?
2) When I fill the gearbox up with gearbox oil, the shafts will be submerged in oil? Or does it not raise above where the shafts are?
3) I just don't understand how something so crude, is able to seal all that oil (if it's submerged), with all that engine and gearbox vibrations. It seems to me it's like trying to hold oil with a fishing net... it just doesn't seem like a very oil-tight seal, with all that movement and vibration going on there.
4) I do see "grooves" just before where the splines meet (kind of like the inside of a gun barrel) Here, and from the direction it looks like it pulls oil towards the center while the wheels are going fowards. If the seals are doing their job, why do they need such design?
Postby TRD_ZERO » Fri Feb 19, 2010 6:35 am
I think its the inner that does the sealing.
Previous:
TRD_ZERO
Postby evil_si » Fri Feb 19, 2010 7:20 am
the outer is a dust cap, the inner seal that is angled inwards does the sealing
evil_si
Postby tsoob » Fri Feb 19, 2010 8:32 am
they do work pretty damm good if they are new, did mine last time the box was out no leaks at all now
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby sergei » Fri Feb 19, 2010 8:49 am
BTW seals do not work well when fully submerged, or there is pressure inside.
You will find that if filled to the right level, most seals will be only just touching oil or not at all.
Postby Akane » Fri Feb 19, 2010 1:54 pm
Okay I'll be taking the axle off once more and check the damn seals.
Sergei if that's the case, I've only managed to get 2.5L into my E153, and it's dripping like crazy already, a big puddle about 200ml came out instantly.
That's why I'm all confused. If I put the recommended 4.2L in, the seals will be submerged, and I don't see how the submerged seals will work at all, a bit like main seals in an engine.
Postby solitaire » Fri Feb 19, 2010 2:10 pm
could it have anything at all to do with the condition of the axles when they went in? :wink:
AE92, KZJ120, KDJ120
solitaire
Postby CAMB01 » Fri Feb 19, 2010 2:27 pm
Are the seals new or old?
What kind of gearbox is it? what vehicle etc.
4.2L sounds like alot unless its an auto?
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby solitaire » Fri Feb 19, 2010 2:29 pm
CAMB01 wrote:Are the seals new or old?
You cant put too much more than you are supposed to in as it flows out because the hole is on the side...
well there are two holes but you are supposed to have the side one open when you fill it so you know when its full
solitaire
Postby jakesae101 » Fri Feb 19, 2010 2:55 pm
my e58 lsd box was 2.6L and so is the e153 if i remeber correctly 4.2 is far to much
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby sergei » Fri Feb 19, 2010 3:00 pm
or 4WD.
I though 2WD EXX gearboxes were around 2.6L?
Postby iOnic » Fri Feb 19, 2010 3:55 pm
4.2L is correct. E153's are pretty big gearboxes.....
(2.6L is the capacity for the non turbo MR2 boxes)
Postby bluemaumau » Fri Feb 19, 2010 4:31 pm
yea i think i had 4.2l in my e51.
which failed big time. for no good reason. just stopped working.
so not too sure on 4.2l
Postby iOnic » Fri Feb 19, 2010 4:40 pm
It's in the Toyota service manual. My gearbox has always taken a shade over 4L before it starts seeping out of the fill hole. I've never really had axle seals just randomly start leaking - it's always been because they got damaged during axle removal/installation. I just make a point of replacing them every time the axles are out now. They only cost like $10
Postby solitaire » Fri Feb 19, 2010 4:44 pm
iOnic wrote:It's in the Toyota service manual. My gearbox has always taken a shade over 4L before it starts seeping out of the fill hole. I've never really had axle seals just randomly start leaking - it's always been because they got damaged during axle removal/installation. I just make a point of replacing them every time the axles are out now. They only cost like $10
Mine takes about 4L too.
I would bet good money his seals are rooted... i was there when the axles went in and if i may liken it to sex it was more like a drunken first time in the back of a levin with rage against the machine cranked up to 11 as opposed to some romantic love scene with barry white playing in the background. :lol:
solitaire
Postby iOnic » Fri Feb 19, 2010 4:52 pm
Lube helps prevent tearing the walls when sliding in too
(take that how you want :lol:)
Postby solitaire » Fri Feb 19, 2010 4:52 pm
iOnic wrote:Lube helps prevent tearing the walls when sliding in too
LUBE IS FOR GIRLS!!!!! :lol:
solitaire
Postby Akane » Fri Feb 19, 2010 5:34 pm
solitaire wrote:could it have anything at all to do with the condition of the axles when they went in? :wink:
Definitely could be :oops:
Old, it's a second hand gearbox, I blew up my first mint one (gnomes somehow managed to undo my oil drain bolt + motorway speeds = almost kissed the barrier when it locked up).
And 4.2L is according to the manual.
solitaire wrote: when the axles went in and if i may liken it to sex it was more like a drunken first..
I think it was more like an elephant trying to have it's way with a kitten.
Last time I've put it in, I used the lower suspension arm as leverage, brake disc as handles, and rammed that thing so violently I'll put a jackhammer to shame. I mean, that's the only way to get it in... or is it? :P
Postby iOnic » Fri Feb 19, 2010 5:37 pm
8O Kenny! LOL. You need a bit of force but not jackhammer force haha that'll damage the CV's (and axle seals)
Postby Dell'Orto » Fri Feb 19, 2010 5:58 pm
Shoulda spat on it first :lol:
