5efe mods
5efe mods
Postby deaf_rattle » Sun Apr 18, 2010 1:28 pm
Looking at getting a 5efe to play around with soon.
Thinking maybe, quad throttles and some decent headers.
Will the quad throttles run alright with the stock ecu and is there anything else that is worth doing to these motors?
Postby iOnic » Sun Apr 18, 2010 3:22 pm
4efte turbo setup?
Postby deaf_rattle » Sun Apr 18, 2010 3:41 pm
rather not turbo to start with. going in a much lighter chassis than normal, so dont need to go too crazy.
Postby iOnic » Sun Apr 18, 2010 3:42 pm
Aah ok. If you havn't got the engine yet, try and find a 5E-FHE. Has a bit more go out of the box
Postby deaf_rattle » Sun Apr 18, 2010 3:45 pm
true, i thought they were the same but had emissions rubbish on them?
sweet as
Postby Malcolm » Sun Apr 18, 2010 4:27 pm
I'm pretty sure the 5e-fhe is a high compression variant. I've also seen some (possibly the fhe's?) with a dual runner ACIS system, which would be a nice to have.
Postby iOnic » Sun Apr 18, 2010 4:52 pm
Yep 5E-FHE = high compression. ACIS is nice too :D All-round they're a better engine than the 5E-FE
Postby mr30%jr » Sun Apr 18, 2010 5:14 pm
unless its a tiny little chassis when your sitting at 1500cc you might as well move to A series..... 5efs are hard to get hold of...
you can usually just plonk an a series in there :lol:
blacktop ftw
mr30%jr
Postby loose_unit » Sun Apr 18, 2010 7:08 pm
5efe = 9.4:1 5efhe = 9.8:1, better cams, better rods and like above have the ACIS mani which works quite well. Theyre quite peppy in something light like a ep71 starlet.
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
Postby 20v_rollaboy » Sun Apr 18, 2010 8:18 pm
loose_unit wrote:Theyre quite peppy in something light like a ep71 starlet.
I can vouch for that too, very fun car to drive with a 5efhe.
20v_rollaboy
Postby deaf_rattle » Sun Apr 18, 2010 9:39 pm
looking at putting into a mini...
did think about a silvertop 20v, but space is tight!
Postby Malcolm » Sun Apr 18, 2010 10:02 pm
the E blocks are quite a lot smaller and lighter so for something as small as a Mini I'd definitely pick the 5E over the 4A. Having said that, I'd probably actually pick something like a 1000cc bike engine :)
Postby Mr Revhead » Sun Apr 18, 2010 10:56 pm
I spy with my little eye something beging with... O
ORSOME!
Postby Dell'Orto » Sun Apr 18, 2010 11:23 pm
So many valves, so little space 8O
Postby Alex B » Sun Apr 18, 2010 11:43 pm
There is one around with B16B turbo too. I would think that car is 0-death in $&#$% all seconds.
Postby mr30%jr » Sun Apr 18, 2010 11:53 pm
yea.... they make 20v bike engines hahaha use one of those still a 20v
mr30%jr
Postby rollaholic » Mon Apr 19, 2010 8:39 am
saw one in an aussie mag a while back with a 4efte, was making 160kw or something apparently.
that would be quick!
Postby Mr Revhead » Mon Apr 19, 2010 9:34 am
Alex B wrote:There is one around with B16B turbo too. I would think that car is 0-death in $&#$% all seconds.
yikes!
At the mini 50th they had here last year there was about 3-4 that had b16as in them. Apparantly someone does a kit for it
Postby 1I1 » Mon Apr 19, 2010 10:11 am
Yup guy in welly does subframes to mount B16A's into them.. Was having a bit of a look at one in Feilding on Saturday with a B18C squeezed in
TRD Clicky >>Here
1I1
Postby ~SlideWays~ » Mon Apr 19, 2010 1:27 pm
Mendoza Mechanical in Upper Hutt built a B16 Mini. Apparently its up and running but I haven't seen it for years.
~SlideWays~
