Igniter for use with Megasquirt
Postby Vertigo » Sat Sep 13, 2014 2:11 pm
Sup, had a poke around Zebra today to look for a Mitsi dual channel igniter. Couldnt find any, but did find a pair of single channel ones, at least I think they are. Part numbers J5T 60572. They have GND, VB, IG+, and IG- pins. These should do the job for a wasted spark 4AGE? Im using 4AGZE dual coil packs.
TVIS just kicked in, yo!
Vertigo
Re: Igniter for use with Megasquirt
Postby jondee86 » Sat Sep 13, 2014 7:31 pm
One of these, found on a number of Mitsis...
Or one of these, found on Legacy turbo wagons and others....
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby Vertigo » Sat Sep 13, 2014 10:57 pm
Yea the J722T is the one I wanted, but couldnt find even one! Ive since located on on Trademe, thatll do.
Would the J5T's do the job, thought?
Vertigo
Postby thegreatestben » Sat Sep 13, 2014 11:48 pm
Just get the two channel, heaps of guys on here seem to frequent wreckers yards. They are really easy to grab.
I found one on a DOHC mirage at pap here in welly after looking for about 2 minutes.
Two will just complicate things.
thegreatestben
Postby jondee86 » Sun Sep 14, 2014 10:46 am
Vertigo wrote:Would the J5T's do the job, thought?
Two single channel igniters will get you there; just means a bit more wiring.
The two channel version has a 12V square wave tacho output, if that is of
any use to you. Should drive an aftermarket tacho no problems.
Cheers... jondee86
jondee86
Postby Vertigo » Sun Sep 14, 2014 12:20 pm
Ideally I would take the tach output and run it strait to the factory tach. Would I need any translation between that and the J722T?
Vertigo
Postby thegreatestben » Sun Sep 14, 2014 12:23 pm
If it's in an aw11 then yes. I had to make a small circuit which was very easy.
I think it's a haltech diagram.
http://img.photobucket.com/albums/v172/ ... dapter.gif
thegreatestben
Postby jondee86 » Sun Sep 14, 2014 1:57 pm
jondee86
Postby Vertigo » Sun Sep 14, 2014 6:04 pm
Great thanks. Found that page in my researching already, and decided to use that exact circuit. I presume -ve terminal is the control line from the ignitors?
Vertigo
Postby thegreatestben » Sun Sep 14, 2014 7:09 pm
If you are referring to my diagram, it is literally the negative side of the coil which is the switched side.
The tach is showing the rate at which the coils are being switched on and off pretty much.
The standard AW11 tach reads only one coil, so when you change to dual coils it'd get the wrong signal.
That circuit doesn't use the ignitor to produce the signal for the tach at all.
thegreatestben
Postby jondee86 » Sun Sep 14, 2014 9:53 pm
If you have a AUX out on your ECU that can be programmed as a TACHO and
can switch 12V to ground, you can use the Mode 2 diagram above. All you
need is the coil out of any small random relay found in a Toyota fuse box at
Pocket-Parts. Disable/discard/destroy the moving parts inside the relay, as
otherwise they will make a buzzing noise and annoy you after a while. Put 12V
on one side of the coil, and connect the other side to the AUX out and to the
tacho input wire.
Job done... no cost... works like a charm... I have it in my car :)
Cheers... jondee86
jondee86
Postby Stu- » Sun Sep 14, 2014 11:25 pm
Or you can change the resistor inside the tacho and not have to run any special wiring.
Project Thread
Stu-
Postby Stu- » Sun Sep 14, 2014 11:32 pm
Re-ignitors - there's several 4cyl mitsi's at Pick a Part west which would have the ignitor you need and likely have the seperate tacho interface too
Project Thread
Stu-
Postby jondee86 » Mon Sep 15, 2014 10:40 am
Stu- wrote:... and likely have the seperate tacho interface too
What does the interface do exactly ?
Cheers... jondee86
jondee86
Postby Bazda » Mon Sep 15, 2014 12:19 pm
Tach interface allows you to pick up a tacho signal. Which you can connect to the rev counter etc.
Thats how I run mine.
Postby Stu- » Mon Sep 15, 2014 12:51 pm
As above, the come standard on some (but not all) mitsi wasted spark setups - little rectangle unit. Combines the high level signal from wasted spark coil outputs so you can run it direct to a tacho that normally runs from a single high level coil. They work ok, but sometimes they can be every so slightly slow to react - I always prefer to run the tacho from the ecu as its super accurate. Although 9 times out of 10 requires the resistor in the tacho to be changed - but its a easy job to do.
Project Thread
Stu-
Postby matt dunn » Mon Sep 15, 2014 8:45 pm
Quite often with the aftermarket tacho's like the VDO ones etc
they will not work correctly from the ECU generated signals and work better from a tach adapter.
Postby Stu- » Mon Sep 15, 2014 9:43 pm
Good to know. I've only had to set up an autometer one for a customer and that was a high level drive, all the rest have been standard tachos which have worked well.
Project Thread
Stu-
Postby Vertigo » Wed Sep 17, 2014 11:31 am
Honestly, I think Ill just go with the dual J5T's and making my own diode tach signal circuit. Seems easier and less error prone to me!
Vertigo
Postby Stu- » Wed Sep 17, 2014 3:19 pm
Yep that will work and making the diode circuit is easy, just not as quick acting and sometimes slightly out from actual rpm.
Project Thread
Stu-
Users browsing this forum: Bing [Bot] and 6 guests
