SR Coupe rack and pinion steering
Postby turbora28 » Thu Jun 10, 2004 1:02 pm
I'd need to confirm this, but from memory the KE70 one is 590mm inner tie to inner tie.
turbora28
sr rack/pinion
Postby crispy'86 » Thu Jun 10, 2004 7:51 pm
What i was referring to shortening was not exactly shortening it physically, sorry. I should have said, and this may sound bloody ridiculous but if the rack ends could be wound in like it was going to be adjusted for a wheel alignment, to give it more toe out on both sides,
Joe, i will measure the distance from knuckle to knuckle relating to the distance between the bolt holes for the lower control arms and get back to you if i get stuck or even to see what it comes to in difference
crispy'86
Postby fangsport » Thu Jun 10, 2004 8:00 pm
Chris, pulling the tie rod ends closer to the rack won't fix your problem, it will amplify it. not only will you have massive bump steer, but you also massive toe out as well. i'll measure the escort rack tonght and report back
fangsport
Postby turbora28 » Fri Jun 11, 2004 2:09 pm
Sorry I made a mistake in measurements...
The RA28 celica, control arm pivot points are 590mm apart.
The KE70 rack inner tie rods are 620mm apart.
So at that point the rack is 30mm too wide for my car cuasing bump steer. Also if you take into effect the ackerman angle designed into the steering knuckles, this is around a 15mm offset from ball joint to outer tie rod.
So this makes the rack somewhere around 30mm too long each side.
I am going to be fitting some AE86 power steering knuckles/steering arms which are around 15mm shorter than the RA28 items. This will make steering heavier but will give slightly more turn and also enable me to lengthen the tie rods by 15mm each side (might need longer tie rods to ensure enough thread).
So yeah, after that will still be 15mm or so too wide. So a shorter rack would be good otherwise might be able to shorten the KE70 this 15mm.
Joel
turbora28
rack
Postby crispy'86 » Sat Jun 12, 2004 12:56 pm
Good point joe, i will be neasuring the rack today to compare it to my crossmember. If i get stuck surely there will be something a bit shorter if needbe.
crispy'86
Postby AE25 » Sat Jun 12, 2004 5:58 pm
confused here... how does adjusting the tie rods change the bump steer? tie rods are adjusted to give the correct toe angle. and how does the ackerman affect it also? as i understand if the inner tie rod ball joints are same width as the control arm pivots then the toe angles will not change when suspension travels up and down. having shorter steering arms will not change the fact that the rack is wider than the control arm pivots. please explain... im learning
E2 & E7 fanatic
http://www.toycrazy.net
AE25
Postby fangsport » Sat Jun 12, 2004 6:05 pm
Mark, you understand good .
fangsport
Postby AE25 » Sun Jun 13, 2004 4:36 am
heres some basic steering info
http://auto.howstuffworks.com/steering.htm
E2 & E7 fanatic
AE25
Postby turbora28 » Mon Jun 14, 2004 1:35 am
AE25 - you are right in saying tie rods are primarily adjusted to set the toe. But I am more refering to the total length of the tie rod (inner tie to outer tie) vs. the length of the control arm pivot point to balljoint.
Lets say the control arm pivot points are 300mm apart, then you have a tierod length of 270mm, there will be bump steer.
Now you cant just go and lengthen the tie rod another 30mm or you'll have huge amounts of toe in. But, if you can shorten the rack 30mm, that means you need to lengthen the tierod/steering arm 30mm. Which then makes the control arm and steering arm the same length.
In my case, i'm going to put a shorter steering knuckle on, which for the tie rod to reach it will need to be extended, so the tie rod length will be getting closer to matching the control arm length.
This doesn't really affect the ackerman much. But I mentioned it as the steering knuckles are mainly what creates the ackerman effect, and when measuring this all up you need to take that into account.
Its like you cannot just make the inner tie rod on the steering rack sit perfectly inline with the control arm pivot point because at the other end (ball joint & outer tie rod) they are not inline due to the offset, ackerman, in the steering knuckle.
In the RA28 there is a 15mm offset in the steering knuckle, so ultimately the steering rack inner tie rod needs to sit 15mm inbound of the control arm pivot point.
I hope that makes some sense! Hard to explain...
Joel
turbora28
sr rack
Postby crispy'86 » Tue Jun 15, 2004 8:42 pm
Yes you are right, i am getting to grips with this. Doing an app. i am going to have to learn all this.
crispy'86
sr rack
Postby crispy'86 » Tue Jun 22, 2004 10:02 pm
so far i have only measured the crossmember bottom arm pivot bolts, haven't had time to measure rack inner. Crossmember bolts are 560mm centre to centre
crispy'86
Postby fangsport » Tue Jun 22, 2004 10:15 pm
looks like you need to shorten the rack then. i'd have to have a look at a spare *E70 rack and see how hard it is to do.
nothing is impossible, just some things are impractical.
Chris, if you have some time up your sleeve, go to a wrecker and measure up some different racks, maybe some like a (dare i suggest it )honda city or a suzuki alto or similar might be narrow enough.
fangsport
rack
Postby crispy'86 » Tue Jun 22, 2004 10:41 pm
Alright thanks Joe, will have a look at a few "OTHER BRANDS" and see what i come up with
crispy'86
Postby fangsport » Tue Jun 22, 2004 10:52 pm
Chris, what about the FXGT, might be worth a quick flick with the tape.
fangsport
Postby gdsup » Wed Jun 23, 2004 1:05 am
jess from boosted performance used a kp60 rack in his yellow 4ag turbo ke26, using original crossmember and fabricating brackets and ke30 colum, not sure as to how this would affect bump steer etc, if you feel the need you can contact him bussiness hours 09-532-8950
gdsup
sr rack/pinion
Postby crispy'86 » Sat Jul 03, 2004 4:38 pm
yeah that's a point joe, i got a spare rack with the fx too just gotta dig it out of the boot, could be worth a look all the same. Haven't had the chance to look at racks etc as yet, still trying to get this engine sorted as in fuel pump wired up check for any fuel leaks in system fit fuel filter then crank it over and see what it does. That ke26 idea may be worth a look but bump steer is a big issue
crispy'86
Postby turbora28 » Tue Jul 06, 2004 12:25 am
I'd really like to hear how wide these KP60 racks are.. We don't get them here in Australia.. So keep me posted guys!
Joel
turbora28
Postby AE25 » Tue Jul 06, 2004 2:42 am
came across another ke20 with a starlet rack this time on www.club-k.co.nz
emailed him and he's replied with these details
his car pics here
http://f2.pg.photos.yahoo.com/ph/headdavey/album?.dir=/91a9&.src=ph&store=&prodid=&.done=http%3a//f2.pg.photos.yahoo.com/headdavey
he probly cant say much more than this...
The bottom arm is off a ke30, hes made up a custom crossmember and put in adjustable camber bolts.
ill try and take some close up ones with the wheel off :)
Steering rack is out of a starlet,not sure what model sorry.
starlet tie rods and just ke30 struts
he used the whole steering column
he just mounted it on the cross member :P
not really too sure on the technical details, as most of the work has been done when im not there
E2 & E7 fanatic
AE25
sr rack
Postby crispy'86 » Wed Jul 07, 2004 10:52 pm
hmmm seems he made a template up and mounted the rack onto that. not long till i can drive car on road and serioudly nutting this out i.e. putting design on paper to practical use
crispy'86
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 18 guests
