gtz gearbox to 20 valve
Postby FLAWLES » Mon May 31, 2004 7:05 pm
this is true
i have noticed from the date thaat i got my gtz that the g-box has slowly gotting worse ie from being dumb and changing gears al-pronto and 1st to 2nd is curnchy
but just a qwick q can you run a bzg 6sp with gtz shafts?????
FLAWLES
Postby 10k 20v » Mon May 31, 2004 7:08 pm
no. The 6 speed uses the same shafts as the 5 speed c52 or c56.
Basiaclaay all the 6 speed box is is a c52 or c56 with an extra cog on the end,
10k 20v
Postby FLAWLES » Mon May 31, 2004 7:10 pm
so u cant stop and change
bugga there goes that idea
FLAWLES
Postby Mr Revhead » Tue Jun 01, 2004 11:57 am
do any of you guy's know how to change gear properly because ive had my celica
celicas use a different box than the corollas. the 'c' series used in corollas is known the world over for 'snatchy' 3rd gear synchros. of course the harder you are on it the sooner it will happen.
Postby TRDWGN » Tue Jun 01, 2004 8:19 pm
:roll: Ummmm the ST16X celica's came with a 4AGE option or 3SGE/TE. I believe the 4AGE powered models used the C52 just like the corollas
TRDWGN
Postby Mr Revhead » Wed Jun 02, 2004 10:37 am
thatll be the at160, and yes it prob woul dhave the 'c' series box
