lowering shocks
Postby wde_bdy » Thu Jul 01, 2004 2:15 pm
badidas wrote:nah man they chuck em on a lathe and take a few mm off the top of the shock and then put spacers on the top side of the top hat under the nut
Which is illegal unless certified.
Callum[/quote]
is also illegal to have un captive springs and its not safe the vtnz had no problems with it this was about 5 years ago tho mabey the rules have changed[/quote]
Yeah I know non captive springs are illegal. What I am saying is that that particular solution (and anything else that modifies a suspension component from factory) requires certing anyway. If your just lowering for looks on the cheap then shocks that don't need modding is the best option. If you want real handling improvements your mods will need certing anyway so spend the cash, do it once, do it right. Shortcuts just bite you in the ass later.
Callum
wde_bdy
Postby PumpN » Thu Jul 01, 2004 11:37 pm
MEX wrote:SnoozinEuro
and if you lower your car you will find the engine and driver and anything in the car will also head closer to the ground taking the roll center down too, and i dont know about you but ive always mounted my seats and engines as low as possible when ever ive been putting new ones in
(Disclaimer: I wanted to own you but I held back, I know im guilty of not reading posts 100% right but it seems that some people dont look into other peoples posts enough and are quick to give advice without a sound understanding of the topic in question)
Your confusing roll center with centre of gravity, your right for centre of gravity being lower, and yes that will be of some benefit to the vehicles behaviour.
The point Snoozin made about roll centre is very valid, when you lower a vehicle you change the roll centre, which is a suspension angle and alignment thing, basically you can only lower a vehicle so far before you make the car handle easily worse then stock (very generally 1-2" with an increase in spring rate is about right). The point Snoozin was trying to make (although he didn't spell it out, if you were real clued up you wouldn't need to be told anyways) is that you can only lower a vehicle slighly before you change the suspension geometry so much that you affect roll centre adversely. Very generally just to give an example that the lay men out there can appreciate, say your looking at the front mac pherson struts on a car, you have an upright coil over shock which bolts to your hub, your hub is connected by a ball joint to a control arm (which is essentially a wishbone) in a normal stance the control arm will angle down from the chassis towards the hub with the hub pivot sitting lower then the pivot point on the chassis, this is very important aspect. When the car is cornering and weight is transfered (and the car tilts onto the outside wheel, we all know what body roll is) the coil over contracts up as the spring is compressed under the load the hub follows and would you now it the control arm does to, now comes the hard part to explain, because of the angle of the control arm and the fact that outside pivot of the control arm is sitting higher it is also further out from the chassis (think of it cutting an arc) this dials in more camber to the the outside wheel and improves that tyres contact patch to suit the cars angle of roll.
The problem is when you lower a car dramatically (even 2" and its very likely your control arms will be level when the suspension is neutral) your control arms dont point down and out like they used to, they are either level or in the worse case point upwards, if the roll centre of your front suspension is like that then as that side of the car becomes loaded mid corner you decrease your negative camber and subsequently the cars contact patch.
To sum things up roll centre is not to be confused with centre of gravity.
Now please, I seriously hope you read his post wrong, cos at least thats better then being wrong :wink: and remember people the only thing worse then being wrong is to be wrong and argueing your point and passing off bad advice :wink:
'92 Nissan 200SX, Need a Daily driver!!!
PumpN
Postby MEX » Fri Jul 02, 2004 1:13 am
im sorry but ive lost the point of this argument...
i understand what you are saying but there are ways to fix it. thats all im saying, for every problem there is a solution. i can fix the problem you are talking about i just cant explain how, i run into this problem on my B6 Mazda. i had to use longer axels to stop them popping out of the cvs on full lock. and i modified my ball joint mounting basicly so it pushed the control arm back down under horizontal
dont have this problem in rwd cars tho drop spindles sort ya out :D
Old Toyota's Never Die... They Just Get Phater
http://homepages.e3.net.nz/~bill-mecchia/
MEX
Postby LowRydr » Sat Jul 03, 2004 10:21 am
heh i always thought sacking your car gave better handeling with the bonus of the car looking boned and cool. ride is much harsher tho road noise is increased and tire wear were the main downfalls i thgouht... and you gotta love the cambered look8)
///TRD Toyota Racing Development
take a really hardcore project idear, making it a reality? .....im 70% there
LowRydr
Postby wde_bdy » Sat Jul 03, 2004 10:24 am
Part of the solution is RCA's (roll centre adjusters), which sit btween the strut and your steering arms. These push the bottom arm lower while leaving the wheel where it was to retain more factory like geometry.
Callum
wde_bdy
