Question about the NZ GT4 turbo
Postby RunningRich » Wed Jul 21, 2004 1:20 pm
Confirmed info on mine. First registered April 94. Not unsual for it to take a while to register them given the $96000 ticket price. Mine was actually purchased by Albany Toyota's Manager and sold after a bit of use.
I have scanned the letter from toyota (with specific vehicle info deleted) so if you want a copy PM.
Richard
http://gtfour.supras.org.nz
RunningRich
Postby subdo » Wed Jul 21, 2004 5:56 pm
Do you other GT4 owners ever meet up?
I supose you're all over Nz eh.
Speaking of GT4SUM........his GT4 was in at the same Toyota Service place as mine 2day.
Hey , about the ct20 -I got told on the alltrac.net site that they rebuild the ceramic turbos (replacing the ceramic parts with steel) in the states. Yet when I tried to get it done here they told me you cant!
Whats the deal on that?
Once you drive it , you'll want it
subdo
Postby RunningRich » Thu Jul 22, 2004 8:38 am
subdo wrote:Do you other GT4 owners ever meet up?
We have had a few meetings, had 10 or so cars together at One Tree Hill a couple of years back.
Richard
RunningRich
Postby RunningRich » Thu Jul 22, 2004 1:44 pm
subdo wrote:Hey , about the ct20 -I got told on the alltrac.net site that they rebuild the ceramic turbos (replacing the ceramic parts with steel) in the states. Yet when I tried to get it done here they told me you cant!
Here's what Cully at Alltech has already written on the subject previously:
Basically the answer is this: CT20B's are rebuildable, but unless there's something specifically wrong with them it's not advised to do so. Ceramic turbine turbos are highly susceptible to failing after rebuild - the bonding between the ceramic wheel and the steel shaft often isn't strong enough to survive the disassembly-reassembly process. Usually any turbo that leaves here which is a rebuilt ceramic will have no warranty on it.
Replacement all-steel shafts aren't available for the 20B - Toyota don't sell the WRC ones separately, and no other third party manufacturer make them. That leaves the option of retrofitting another shaft from a different turbo, however this is harder than it looks. Toyota use a shaft profile that is different to just about every other turbo in existence, and at very least you'd be looking at a large machining cost on top of an expensive new shaft, IF you could find a suitable shaft to start with.
We've just recently retro'd our first steel shafts into a 2.5L TT (1JZ) Supra with good success, and potentially the same could happen for the 20B in the future, but I wouldn't be holding your breath that parts will become available.
Otherwise if they need a recon then they can be done - no different to any other turbo, you just run the risk of the turbine snapping.
Talk to Cully at Alltech for more info.
Richard
RunningRich
