GT4 Problem
Postby Al » Sun Aug 08, 2004 9:36 pm
Dude. I had knock on my STANDARD mr2 at 10psi on 96 octane fuel when i was racing at the drags.
Next time ran a tank of avgas...no more knock.
Al
Postby matt dunn » Sun Aug 08, 2004 9:55 pm
WALT3R wrote:FLYGT4: wen u put too much boost thru the shitty stock intercooler as said b4...it will detonate enuf to trigger the knock sensor and retard the timing.
As this chaps engine is stock, i dont think youd have any problems with this hence why no need to run avgas..... might as well put nitrogen into the tyres while hes at it haha :lol:
I suggested trying avgas for a tank to try and prove the if it is a detonation problem, not as a permanent solution.
The ones i have worked on, Definatlty had detonation problems when running std boost and std timing being 10 deg BTDC. Avgas fixed the hesitation problems, so did dropping the timming back to 5 degree's.
Matt
