20v and coolant level
Postby AceSniper » Tue Aug 31, 2004 2:17 pm
Holds 5.3lt
AceSniper
Postby strap-on » Thu Sep 02, 2004 12:23 am
ok i dont know wat im doing wrong then but it took less than 1.5 litres to fill back up :S, i drained it, filled with water, ran it to operating temp, drained it again, filled it up with 50:50 and yeah it took less than 1.5 litres, i mustnt be doing it rite :( im such a n00b,
I MUST SAY TO EVERYONE A BIG THANK YOU FOR BEING PATIENT WITH ME AND MY n00bNESS WITH THIS MATTER.
strap-on
Postby kingcorolla » Thu Sep 02, 2004 5:32 am
-drain
-mix
-fill
-run to temp
-top up
thermostats take 10 secs to shut. thats prob why it fukd up on u
1983 Carina AA63 4age
kingcorolla
Postby levin_it_large » Thu Sep 02, 2004 11:50 am
yeah when i did my coolant it was probably about the same as that, hmmm *wonders, what wrong with my radiator?
levin_it_large
Postby Mr Revhead » Thu Sep 02, 2004 11:53 am
sounds like youv changed the coolant in the radiator ok. just not the rest of the engine! what hose did you disconnect to drain? the 20vs are a lil different from other engines, they have a thermo stat onthe bottom hose, so if you drop that it wont drain the engine
Postby strap-on » Thu Sep 02, 2004 6:56 pm
i just drained that little tap thingee at the bottom was i supposed to do the hoses as well?
and thanks kingcorrola thats probably the best advice ive had so far
strap-on
Postby AceSniper » Thu Sep 02, 2004 7:07 pm
not sure if this is true... but also have ur heater controls open to drain the water outa it aswell? *shrug*
AceSniper
Postby Mr Revhead » Fri Sep 03, 2004 12:09 pm
yup should have heater on as well
to do it really well heres what you need:
1 tank with a tap in the bottom to attatch a hose to, fill this tank with your coolant mix. run the hose to the engine, depending on what hose does what.
run another hose from the outlet of the what ever you unplug, and run that to a catch tank.
that way you wont get any air locks, but if your coolant is quite dirty then you may want to use just water to do that as it gets priecy flushing rads with antifreeze!
