$1800 and only done 3500kms
Mr Revhead wrote:$1800 and only done 3500kms
how many ks???
for $1800 you can get a 20v, rebuild it with good bits and still have $$ left over for box and axles. if your doing the work yourself or have someone youll do it cheap. the only times id recomend starting with a gze is if you already have one, or have to pay for ALL the work
the point is 9 time out of 10 its cheaper and better in the long run to convert something else rather than try and find a 4agze.
doing that gives you an engine that you KNOW will handle what your planning, rather than something with an unkown history.
1000 left for a engine, rods, pistons, bolts, head gasket, bearings, labour, ecu. hmmmm
Users browsing this forum: Bing [Bot], Google [Bot] and 27 guests
