If u hear the sound of bov when u step on the clutch...
Postby alastabesta » Sat Nov 06, 2004 6:39 pm
how do u change the clutch...?
is there like a step-by-step instruction on how to change one...? :roll:
2001 Caldina GT-T
alastabesta
Postby [V8ROLA] » Sun Nov 07, 2004 8:18 am
yeah its called "if you dont know what your doing get a pro to do it :P"
as for this hole in the gearbox where is it located?? if its only into the clutch area (get a plate for it, dosn't take much to tap 4 holes and stick a piece of steel over it to stop stones etc getting into it.) it might have nothing to do with the raunching of the gears etc.
first thing i would do is bleed the clutch system and go from there as celica_tommo said, look for leaks also THEN start looking at the more $$ things.
1995 ducati 900ss with a 2001 fuel injected motor, ramflow intake, open pipes, polished wheels and afew other mods.
more to come ;)
1983 RX7 series 2 with small block chevy.
http://photos.data.net.nz/?dir=V6ROLA%2 ... sion%20%2F
[V8ROLA]
Real Life Mechanic
Postby JT » Mon Nov 08, 2004 4:59 pm
Are you sure it has a hole in it? I thought my old one had a hole where the bellhousing met the engine at the bottom of the box but I took a look at another one and it was exactly the same so must just be the shape of the housing. This was a facelift ae101 gt-apex so it has the same box as yours.
JT
Postby celica_tommo » Mon Nov 08, 2004 5:11 pm
I think most gearboxes have a rectangle chunk out of the bottom to let water, oil, transmission fluid out pressumably
celica_tommo
Postby alastabesta » Wed Nov 10, 2004 3:33 pm
just got the mechanics to take everything apart and now its confirmed that the clutch is doing fine and no problem at all apart from excessive wear but the actual g/box is pretty much f**ked up :?
would anyone know anything about fitting a bzr g/box into bzg? would the 6speed fit into where the old gearbox sits? or would I need some modification to "make it fit"? I tried searching for it but couldn't find one but I'm sure theres ppl who's done it before...(hopefully.. :oops: )
thank you all 8)
oh forgot to ask, how much would i be looking at for both 5speed and 6speed g/box?
2001 Caldina GT-T
alastabesta
Postby 10k 20v » Wed Nov 10, 2004 6:19 pm
you have to change your shift clabes and your shifter to change to the 6speed apart from that it's a straight swap
what are you gonna do with the old box?
10k 20v
Postby alastabesta » Wed Nov 10, 2004 7:44 pm
i duno - if anyone wants it its urs for free...?
condition - damaged. lol
tho i duno how i'm gona carry the g/box home... so prob if u pm me with ur cell phone number and i'll txt u soon as the mechanics give me a buzz to pick up the car?
the location is forrest hill motors in northshore, auckland. (off forrest hill road in forrest hill)
8)
2001 Caldina GT-T
alastabesta
Postby 10k 20v » Thu Nov 11, 2004 6:41 pm
pm sent
10k 20v
