vvega wrote:the other option id to get a ignition only ecu and tri that link also sells one of those
v
v
hare wrote:ignition only ecu????who make it?vvega wrote:the other option id to get a ignition only ecu and tri that link also sells one of those
v
vvega wrote:hare wrote:ignition only ecu????who make it?vvega wrote:the other option id to get a ignition only ecu and tri that link also sells one of those
v
http://www.link-electro.co.nz/lem_ignition_link.html
ants_ae92 wrote:Sorry to jack the thread here guys, but I have a 4age 16v that has no rev limit or speed cutout! Would that mean an aftermarket ecu was possibly put in?
I rev my 4age ae92 levin to 8k rpm, and have clocked it with the needle going way past 180, at a guess 200. (not on public roads of course)
No possible way that this is a standard ecu?
slighty_sykotic wrote:The speed limiters arn't so easy to bepass in toyotas though. Cause to do it (snice they can't be chipped) you remove the speed input to the ecu, which cause the ecu to get upset and throw codes and maybe even lights around.
--Sykotic
slighty_sykotic wrote: What does the ecu sample the speed for? any clue?
--Sykotic
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
