gear oil
Postby celica_tommo » Mon Apr 18, 2005 6:21 pm
TygerTung wrote:Insted of buying the expensive injection setup, you can easily just get a funnel and some clear plastic tube from the local hardware store for about $3 all up.
Use some 100mph tape to make sure theres a good seal between the tube and the funnel.
Did it the other day on a VR-4, worked mint.
All these fancy oils arn't necicary in my opinion, I just use average garden variety gearbox oil, works mint!
or even better, go to the $2 shop an buy one of those syphon things with the little pump in the middle takes a little while but it's really easy and no mess
celica_tommo
Postby LEV_101 » Wed Apr 20, 2005 4:40 pm
finally... found the filler hole ... YAAY ! can someone please give me the brand and the code for the gear oil you gurls/guys recommend. and also tell me the place which you can get it from ...
LEV_101
Postby fuel » Wed Apr 20, 2005 10:49 pm
80W140 is a bit thick to be using isn't it sergei?
80W90 Castrol EPX or 75W90 Valvoline Duragear GL5 should be fine. The Valvoline is $25 or so for a 4 litre pack, and it's good stuff.
LOUD NOISES!!!
fuel
Postby Lloyd » Wed Apr 20, 2005 10:53 pm
Something around the 80 mark should be fine, be it 80 or 80W90. You'll find stuff marked as manual transmission fluid and have an SAE rating on it of around 80. Thats the stuff you're after
Postby sergei » Wed Apr 20, 2005 11:32 pm
I use Castrol Syntrax ($$$) , very good oil, very expencive ~$90 for 4lt
Postby ROBODISCO_20v » Sun Apr 24, 2005 5:44 pm
I've also get Castrol Syntrax 75w90 in my 111.
Its the only gear oil Fraser cars will use. It improved my gear changes. It is expensive @ $90 for 4L. An ae111 takes 2.5L. I have a spare 1.5L at home you can have for $20
ROBODISCO_20v
