Some surf questions.
Postby CozmoNz » Tue Mar 22, 2005 4:42 pm
Mr Revhead wrote:thats like saying they have 4wd casue they go offroad often.... :wink:
im unaware of any overboost problems, dont know why they did it.
some diesels have throttle bodies.
if its sucking cosmo, how can it be 0 vac? if it was 0 vac it would run. ALL combustion engines need vacuum to run
ok, im not going to try think it out, coz i cbf.
deisels have tbs to shut them off when you turn the key off >.>
viewtopic.php?t=27668&highlight=bov+diesel
Rayne For President!
CozmoNz
Postby Mr Revhead » Tue Mar 22, 2005 5:20 pm
close... but not quite... the comment on restriction in the manifold is applicible to BOV, but not vacuum in the intake.
there are toyota diesels that run a TB. which as stated is used to help shut them off..... but also to control the airflow. the 1KZTE which is a turbo does this :wink:
it probably acts more like a boost surge controller than a proper TB. but you get the idea
Postby Rob » Tue Mar 22, 2005 8:19 pm
Most deisels have a vacuum pump on the back of the alternator and is then then distributed by little switches which are electrically controlled.
Surfs are crap, don't buy one as i don't want to see it on my hoist
1990 ST185H - project
1996 VS Acclaim wagon
Rob
lights
Postby Fandango » Wed Mar 23, 2005 4:53 pm
Ive seen these lights on surfs, I recon green = most economical range
orange= power
I doubt it would have a 'overboost light' thats stupid. They wouldnt make the engine overboost from factory.
Ive never seen it on any other car, so why on a surf?
When I did my time at toyota, there weir at least 4 in the workshop getting overhauled etc , REAL crap engine apparently.
Apparently mitsubishi, toyota use the same blocks as their petrol engines. making them very weak due to the much higher stresses.
Fandango
Postby Mr Revhead » Wed Mar 23, 2005 5:25 pm
fandango.. not meaning to be rude.... but your all wrong there....
and they are not a bad engines, just the worst that toyota have ever done!
which is still better than a lot of others!!
Users browsing this forum: Google [Bot] and 17 guests
