yup 20v ones are about the best you can get untill your pushing 200hp.
yup gotta slot the two outer holes.
i can supply TRD multihole pulleys.
to be honest those mods while they may do something, i doubt youll feel it seat of the pants.....
vvega wrote:maybe redialing your cams will help you get what your after
gordon77 wrote:vvega wrote:maybe redialing your cams will help you get what your after
by this you mean.....
i am beggining to think that what i am after is near impossible in a small engine without sacrificing high end power
240°
7.56mm
9°BTDC
(Stock -max lift @ 111°)
51°BBDC
Stock 4AGEU used on AE86 and AW11. P/N Intake 13501-16010. Ex. 13502-16010. Some have found good power setting the maximum lobe lift for the exhaust at 100°BTDC and intake at 100°ATDC. For more bottom end power retard the exhaust 4° and advance the intake 3°. For more top end, advance intake 4°and exhaust 3° from stock settings.
